Oil drain bolt stripped
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Oil drain bolt stripped
    john_aero is offline Senior Member
    May 2007
    Kildare Ireland
    was out today giving the @ a service, dropped oil, cleaned bike up a bit, great, put new filter on and wiped down old oil.
    hand threaded the sump plug in, check manual, 35n/m??? seems tight so set torque wrench at 30NM and away i go, half a turn and bang, treads stripped.
    So anyone know a solution to repair the threads without having drop engine out?
    it was awful tight when took it off so think someone might have cross threaded it hen last put it in as i had baerly startd tighten it up when went
    Boris's Avatar
    Boris is online now Wrinkled member
    Oct 2006
    Edinburgh, Scotland
    Re: Oil drain bolt stripped
    I'd look to see how much meat there is and see if I could helicoil it. Dead easy to do and helicoil kits are pretty cheap these days form the likes of Machine Mart. They do an own brand kit that is identical to the helicoil kit bar the colour of the tools
    I'm on the Safe House List
    May 2007
    Kildare Ireland
    hard tell, the sump seems very thin and dont think much to play with onone side.
    helicoil great job it access thats the problem, its on the side, want try avoid stripping engine out of frame
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    I use these. Recently repaired a botched Honda C90 drain plug thead using this system. The finished product is more permanent than Helicoil.
    ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
    Try your local car garage, they probably have the kit and as a one off its probably cheaper than buying the kit.
    You do need direct access for the drill and fitting method. Not sure about access to the AT sump.
    RWB XRV 750
    Red XRV 750
    BlackXRV 750
    GL 1800
    Yellow Honda Trail 90 - CT90 no 1
    Red Honda Trail 90 - CT90
    Red Honda Trail 110 - CT110 Special
    Yellow Honda Trail 90 - CT90 no 2
    Horses for courses
    May 2007
    Kildare Ireland
    thoes look very good, i like fack its got a top hat on it stop it going too far in
    looks like i will have drop engine out
    Cookie is offline Toolbox
    Feb 2010
    Nieder-Olm, Germany
    If you decide use a Stahlbus drain plug, youŽll only have to use the thread one more time: Change oil - clean and simple
    I got those both on the XL700 and the XRV750 and love the simplicity of an oil change.
    Chris
    Chris
    May 2007
    Kildare Ireland
    how does it work, just threads into oil plug and a valve at other end is it?
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by Cookie View Post
    Chris
    Chris
    Good idea but thats very expensive, any hydraulics shop will make you oe of those hoses for less than a tenner and will more than likely be twice the quality
    GASGAS EC300 2006
    May 2007
    Kildare Ireland
    had a look today at sump.
    looks like plug thats in the bike was wrong thread type and also very short.
    so i think the threads damaged were the 1st 6mm, there is still another 6-7mm f thread further in so a longer bolt will sort me out.
    so might look at trying another method, i will fit longer bolt but might try make up a drain pipe on the end to aid oil draining so dont have take the bolt out again
    so lastly how important is a magnetic plug, would it be major down side if left it out and fitted a drain bolt that did not have one fitted as think i have a sump bolt without a magnet
    Jakey is offline Senior Member
    Nov 2011
    Bedfordshire
    Magnetic bolt isn't major (no one fits them as standard). It's just nice to have, extra protection.
    Like crash bars, no need for them but if the worst does happen they may help. But chances are damage will occur anyway
  1. Replies: 39
    Last Post: 23-04-11, 07:54 AM
  2. Fork drain bolt
    By thetimkirby in forum Africa Twin
    Last Post: 21-09-10, 09:43 AM
  3. Stripped TA??
    By El Vencejo in forum Transalp
    Last Post: 04-04-10, 10:02 AM
  4. Engine stripped, need advice
    By Flipatron in forum XR
    Last Post: 20-09-09, 09:15 PM
  5. Replies: 2
    Last Post: 26-04-09, 08:19 PM
