cold starting in the morning without chokes in
Results 1 to 6 of 6
Thread: cold starting in the morning without chokes in
    R0vers's Avatar
    Mar 2007
    South London/Somerset
    Having taken out the chokes in the summer, this moring i just couldnt start her and the battery became dead whilst trying to turn her over - until the clikcing started. so had to resort to taking the bus
    i am going to put the battery on charge when i get back tonight and hopefully give it another go tomorrow - need to fill her up as only just switched to reserve - so could be affecting the fuel pump..
    has anyone else had problems with starting in the cold,having disconnected the chokes?
    TLD2008 [COLOR=Red]15.41[/COLOR]
    AlanH's Avatar
    Bristol, UK
    Re: cold starting in the morning without chokes in
    I never disconnected the chokes but my RD04 would not start without choke when it was very cold.
    KTM 990 Adventure
    racinghero55's Avatar
    racinghero55 is offline Senior Member
    Jun 2010
    Billericay, Essex
    I never use the choke and use my bike daily (early morning 7am - zero degrees this morning). I do keep her in the garage overnight so maybe that helps, but all she needs is a little bit of throttle and she wakes with a lively burble from the Remus. I gently raise the revs to 2000 hold there for 15 seconds and she can then happily be left to tick over at 1,250 ish. Maybe I'm just lucky....although my previous rd07 was also just as happy to start early morning without choke.
    Sent from my iPhone 4 using Tapatalk
    foz1969's Avatar
    Jun 2009
    Seriously... try to cover as much of the engine with an old quilt. It does make a difference.
    Bolton, Lancs.
    Yes mine is a bit tricky when its really cold. . . . just a touch of throttle then hold it for good few second's. its kept inside and i often have the optimate type charger on just in case.
    R0vers's Avatar
    Mar 2007
    thanks for your commnets and suggestions guys.. i like the duvet suggestion Foz...
    went to take the bvattery out lasnight to charge it - but thought i would just see if she turned over - and bang - fired first time!!!! - so filled here up and went for a long run to charge her.this morning she fired up first time aswell.... so i am really pleased..
    i have suspected for sometime my fuel pump not working 100% - so im going to look in to Facet upgrade.
  1. XR 250 Cold Starting
    By BIG Baz in forum XR
    Last Post: 29-11-12, 08:25 PM
  2. Replies: 22
    Last Post: 19-01-12, 10:14 PM
  3. Starting XR400 from Cold
    By PaulXR400 in forum XR
    Last Post: 12-01-08, 06:54 PM
  4. Cold starting
    By Biggy in forum Transalp
    Last Post: 09-12-07, 10:05 PM
  5. starting from cold
    By churches67 in forum Dominator / FMX
    Last Post: 24-03-07, 07:24 PM
