Results 1 to 3 of 3
Thread: Breather Pipe from Airbox - why?...
    landyandy is offline Senior Member
    Kent & London - whereever, really
    Hello.
    Why does this pipe (the one that hangs down past the swingarm) have a tap on the end of it? Surely it's only any use if it can breathe?
    banger is offline Senior Member
    Aug 2004
    ireland
    Haven't really looked at the tap to see if its an on off tap or non-return arrangment,
    but it would be no use if it were open as the air box is under negative pressure when the engine is running, therefore water would not collect in it to be drained off, instead you would get all sorts sucked up the tube into the air box.
    Oops - better put it back on sharpish then!
  1. Replies: 18
    Last Post: 17-10-08, 11:50 AM
  2. Crankcase breather cap
    By kiroh in forum Africa Twin
    Last Post: 10-03-06, 01:10 PM
  3. Airbox pipe fitting query
    Last Post: 26-09-05, 02:40 PM
  4. Airbox modification
    By stueydo in forum Africa Twin
    Last Post: 07-05-05, 06:41 AM
  5. Crankcase Breather?
    Last Post: 03-08-04, 09:29 AM
