Digital Trip Problem
Results 1 to 6 of 6
Thread: Digital Trip Problem
    miggy is offline Senior Member
    Jul 2004
    London
    Quite simply it's not working, no signs of life at all. This is on a 1992 AF that I've just got (the previous owner isn't available to ask at present) so....
    Where's the fuse for it? Is there one? Is there some switch that I don't know about? Oh yeah, it's originally an Italian model. The previous owner is in the forces and has imported it so I assume that it will read in Kilometres when/if working, right?
    The bike is otherwise great.
    Mine died when one of the wires into the block connector behind the pod, corroded and separated. Remove the tripmeter and check all the connections. I would imagine it doesn't have it's own fuse but shares it with other items which you would have noticed not working.
    1 Varadero/34,000 miles ridden (of 57,000 miles on the bike), it's all still new to me!
    Jul 2004
    London
    Supposed I'd better open it up and have a look then.
    No need to open it. Pop the screen off the fairing and you'll see two 10mm domed nuts holding the trip meter onto the bike. Once you've removed these, you can lift the trip meter up a little and expose a line of block connectors. One of these is the trip meter supply and it's here that all that nasty roadsalt gets in to the block terminals and makes them break off.
    It's worth checking out all the adjacent block connectors whilst you can see them, to see if any of the others are affected.
    Jul 2004
    London
    Yeah that's what I meant, I check it out.
    Jul 2004
    London
    The connectors are ok, 12V coming thro'. I also opened it up and get 12V at the circuit board at the soldering points so how come there's no display whatever.
    Maybe the LCD display is knackered? (I'm assuming that I'll get a display with just the ignition switched on right.)
  1. Digital Trip
    By paul_r in forum Africa Twin
    Last Post: 10-03-06, 09:45 AM
  2. Digital speedo/trip meter
    By Muckybill in forum Africa Twin
    Last Post: 06-12-05, 12:18 AM
  3. +Digital trip/clock unit display
    By dod in forum Africa Twin
    Last Post: 01-06-05, 06:50 PM
  4. Digital Trip Meter - from the owners manual
    Last Post: 26-02-05, 06:10 PM
  5. Digital Trip How much?
    By miggy in forum Africa Twin
    Last Post: 28-09-04, 12:22 AM
