Results 1 to 7 of 7
Thread: Rust !!!!
    jvaughan is offline Senior Member
    May 2004
    Andover, Hampshire/ London/ South Wales
    Rust !!!!
    Started the AT up on sunday, and went for a blast before giving the bike a good clean. when I put the bike on the center stand, and gave it a good soaping, I decided to give the bike a little "rev". About 3000 rpm I noticed a distinct vibration comming from the rear.
    Upon further inspection, it turns out that the rear exhaust gaurd has rusted and snapped right on the joint.
    Im a bit pissed, as the bike is only 10 months old, and only has 5000 miles on the clock (is garaged when not in use).
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Hmmn, the body work looks subtley different to mine too...I'm guessing that's an RD07a then? :P
    Jim
    '95 R1100GS
    '80 XT250
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Re: Rust !!!!
    Quote Originally Posted by jvaughan
    Yeh same with me too I noticed mine after 12 months.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    DM
    DM is offline Member
    Jun 2004
    London
    Presumably this will be covered under the warranty though guys? I noticed the bracket holding the back of the exhaust on mine has some corrosion on it too - is this the same bit you're talking about?
    May 2004
    Im not sure..... Will have to check....
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    I don't think rust is covered under warranty as Honda argue that you haven't cleaned the bike properly.
    I.e. wipe it down after every ride
    Well that's what my dealer said anyway.
    Totally impractical in my opinion.
    2010 KTM 450 EXC-R
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    Whilst you might expect a bit of surface rust in that time scale (although personally I wouldn't), to rust through a bracket like that has got to be a manufacturing defect. If Honda won't fix it under the warranty I'd be tempted to get Trading Standards people involved.
    What other more safety critical brackets might also break during a ride? Do you really want to find out the painful way?
    Iain
  1. anti rust
    By 2OLD4THIS in forum Mechanical Advice
    Last Post: 19-12-06, 08:02 PM
  2. spring clean beat the rust
    By jabba in forum Africa Twin
    Last Post: 25-05-06, 02:44 PM
  3. Rust
    By Maverick in forum Africa Twin
    Last Post: 17-10-05, 10:19 PM
  4. Rust
    By jabba in forum Chatter
    Last Post: 20-02-05, 04:46 PM
