Reg/rec?
Results 1 to 4 of 4
Thread: Reg/rec?
    Boomer is offline Member
    May 2011
    Swindon
    Reg/rec?
    Last summer when I was riding my @ I kept getting a dead battery when riding with lights on. I changed the battery, but the problem persisted.
    I dragged her out today and went for my first spin of the year, on my return I got the voltmeter out and got the following readings:
    Idle- lights off 14.6
    Idle lights on 12.7
    Lights off
    3000 rpm 14.5
    4000 14.6
    5000 14.6
    Lights on
    3000 12.9
    4000 13
    5000 13
    Does this look about right or do I need to look at a new reg/rec.
    Thanks in advance!
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    An event Horizon somewhere
    Re: Reg/rec?
    Got to say that the figures you've given look OK to me, in that your not getting anything over high 14v at most revs. If the reg/rec is fubared you commonly see 15+v at anything past 2k revs.
    Someone with an in-depth knowledge of electrics will be along soon to give a definative answer to your question
    Steve T
    Quick edit as I've just found the outputs from my @ with the original reg/rec fitted:-
    The battery was showing 13.18v with the engine off
    Idle = 12.81v
    2k revs lights on = 14.11v
    2k revs Lights off = 14.35v
    I've now fitted a Mosfett reg/rec cos there was one for sale on here & I fancied a fully digital @
    Cookie is offline Toolbox
    Feb 2010
    Nieder-Olm, Germany
    Re: Reg/rec?
    Looks good to me. To get best charging, check your negative/earth/ground whatever you call it in English connection between battery and frame; check the three yellow cables between regulator and alternator (those which should get rid of the in-between plug anyways). Other than that be reminded that e.g. heated grips & foglamps at the same time will use more amps than the battery receives, south of Vmax.
    Chris
    foz1969's Avatar
    Jun 2009
    Re: Reg/rec?
    good link, lots of friends have used too, posted to my faves, printed & keep in manual. cheers lutin
    http://www.electrosport.com/technica...ng-diagram.pdf
    ”If you don’t have anything nice to say about people, come sit over here by me”
