Rally Replica Build (or should this be Johm_aero copies Stormforce) - Page 3
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
Thread: Rally Replica Build (or should this be Johm_aero copies Stormforce)
  1. #21
    john_aero is offline Senior Member
    May 2007
    Kildare Ireland
    Re: Rally Replica Build (or should this be Johm_aero copies Stormforce)
    ya i lost count hahahah
    May 2007
    Kildare Ireland
    ktm forks arived and got headlight location mocked up
    have make new cross bar as it is sitting high and to the left a bit much
Size:  52.0 KBName:  Photo0431.jpg
Size:  46.0 KBName:  Photo0432.jpg
Size:  60.9 KBName:  Photo0433.jpg
  4. #23
    May 2007
    Kildare Ireland
    fairing bracket nearly done
  5. #24
    May 2007
    Kildare Ireland
    good news here
    but i hade butcher my brackets as i had elongate and ovalize all the holes to get everything to aling up.
    so will make up new ones in time ones have everything done
    headlight can do with being moved over slightly
Size:  46.3 KBName:  Photo0436.jpg
Size:  47.5 KBName:  Photo0437.jpg
Size:  49.3 KBName:  Photo0438.jpg
Size:  52.6 KBName:  Photo0439.jpg
  6. #25
    May 2007
    Kildare Ireland
    ok got 30min to make up a 2nd T-bar to hold the road book and dash
    BUTTTTTTTTTTTTTTTT what **** the whoe lot is arse ways and all twisted. then realised th epillar drill was off, even thoguh set at zero it wasnt lever
    had re do it all again, made total bolox of it and then on top that broke the 4mm tap in the hle for rond bar. its now acting as a peg hahaha and will tack weld it up next week just made sure its secureName:  Photo0443.jpg
Size:  48.2 KBName:  Photo0442.jpg
  7. #26
    wilso122's Avatar
    wilso122 is offline Member
    Jan 2012
    United Kingdom
    Looking good, just finished the transalp conversion, so perhaps a little inspiration for when you have your spanner in hand looking blankly at what needs to be done next, its well worth it! the USD front fork transform the bike beyond belief!
    Huge Thank You to Rugged Roads!
  8. #27
    May 2007
    Kildare Ireland
    forks on, had few issues but look well
Size:  59.1 KBName:  Photo0453.jpg
  9. #28
    wilso122's Avatar
    Jan 2012
    United Kingdom
    That was my happiest moment, starts to feel like a bike again looking well!!
  10. #29
    May 2007
    Kildare Ireland
    going to make up a new frotn axel to allow me use the original wheel.
    running outa money so cant afford rebuild the ktm wheel.
  11. #30
    wilso122's Avatar
    Jan 2012
    United Kingdom
    Is that going to work? the original spindle is way smaller than the KTM, also on mine the original hub I seem to think is narrower especially with the speedo removed.
    This one any good to you? KTM EXC FRONT D.I.D WHEEL COMPLETE AND TYRES DID 21 inch motocross enduro | eBayn your picture above is that the ktm or @ hub?
  1. Ktm 660 rally factory replica -04
    By Kjell Lindberg in forum Everything Orange - KTM
    Last Post: 24-03-09, 09:44 AM
  2. Stormforce and Annette
    By Sharribee in forum Chatter
    Last Post: 26-05-08, 11:13 AM
  3. Hey Stormforce
    Last Post: 02-02-08, 11:12 PM
