Rally Replica Build (or should this be Johm_aero copies Stormforce) - Page 4
Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 58
Thread: Rally Replica Build (or should this be Johm_aero copies Stormforce)
  1. #31
    john_aero is offline Senior Member
    May 2007
    Kildare Ireland
    Re: Rally Replica Build (or should this be Johm_aero copies Stormforce)
    i have both ktm and original @ hubs.
    reason dont want use ktm wheels is i have rebuild it with new SS spokes and gold sm rim to mach my rear one.
    have 3 axles, have axel same leght as ktm but thinner to suit @ hub. i am getting sleeve pressed onto the right side to makeit the same thickness as the ktm axles, and a nut for the left with a threadded internal section that acts as the end nut and sleeve for the left leg. these will also incorporate the spacers so i wont have try fiddle with spacers when fitting wheel.
    i am not sure what do with speedo lugs on wheel, maybe grind them off
    wilso122's Avatar
    wilso122 is offline Member
    Jan 2012
    United Kingdom
    Coolio mate, just wondering why you couldnt use the exiting rim was all + wanted to know how you got on as considering putting an 18" rear on the TA
  4. #33
    May 2007
    Kildare Ireland
    exisitng ktm rim was shot along with spokes so last lad removed them to reduce postage costs.
    rear.....if i had done conversion now i would go 18in rear, but i had built wheels last year before concidered this project
  5. #34
    May 2007
    Kildare Ireland
    where do all the wires go.............
Size:  21.1 KBName:  dash side.jpg
Size:  19.9 KBName:  dash rear.jpg
  6. #35
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    well that red wire certainly doesn't go to the yellow one...............................
    Nice to see the F2R mounted
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    2008 - BMW F800GS - BumbleBee
    2003 - BMW R1150GS - Graphitan
    2002 - Honda Africa Twin XRV750 RD07A RWB
    1997 - Honda Africa Twin XRV750 RD07A Fast Black
  7. #36
    May 2007
    Kildare Ireland
    do i cut the blue or red one.hhhhhmmmmm
    got figure way try make all lights on dash work.
    i think what i only hav eleft is order soem posi locks and taps as i run out to splice into the main power lead in ignition (hence long red wire)
    then try see how get the low beam indi on dash working. think as lights come on auto if i wire wire from dash into the switched power lead then when key is on they green light showing lights are one should work
    the roadbook is a nice job must say and for the money compared to the rest they are great quality
  8. #37
    May 2007
    Kildare Ireland
    fork springs on order now, calliper hangar ordered also.
    so waiting for lad to make axel spacers up...maybe i should have just laced new gold rim on ktm hub been so much faster and handier.
    wiring getting there, dash all done just fit sensors when i get wheel on and have bike rolling.
    have fit upgraded fuel pump thats in th ebox.
    have tank off so going tidy loom up after alarm removal, check valves seen as have tank off and give bike a good clean up under there before assembly
    next item be painting, have get decals for the front fairing then last item to buy...new shock
    so hopefully if mate pulls the finger out i should hav ebike done fats enough, just getting tim is the killer
  9. #38
    May 2007
    Kildare Ireland
    Dash from frotn and side showing all wiring in and tidies up. relayed all mounted on new alu brackets to keep fitting as close to stock as possible
    Name:  Dash Front.jpg
    Front wheel with smp pro rin SS spokes and custom 320mm floating disc
    Name:  New Front Wheel.jpg
    Relay fitted so i now have spare fuse powered in fuse box running 12v socket gps and road book. fuse is 30 amp. but there is still a 2amp fuse on gps/roadbook line and will fit 25amp fuse on 12v socket lin
  10. #39
    tendays's Avatar
    tendays is offline Senior Member
    Jun 2006
    birmingham uk
    proper job there young man
    /td
    dl650k7
    drz400sk5
  11. #40
    May 2007
    Kildare Ireland
    getting there. had stopped working on it for while due work around house. so there is max 2 days work left just have get time and material to do the last few bits
  1. Ktm 660 rally factory replica -04
    By Kjell Lindberg in forum Everything Orange - KTM
    Last Post: 24-03-09, 09:44 AM
  2. Stormforce and Annette
    By Sharribee in forum Chatter
    Last Post: 26-05-08, 11:13 AM
  3. Hey Stormforce
    Last Post: 02-02-08, 11:12 PM
