Results 1 to 5 of 5
Thread: forks
    nimrod is offline Member
    Jul 2004
    London N W
    forks
    Am intending to change front fork oil as bike is currently very soft up front. Looking at a 10 wt med fork oil. Will 1 litre be enough ?
    Any other suggestions ?
    Cotswolds, UK
    You need 648 cc for each leg (standard is 5W), or 635 on '90-92 models, provided you get all old oil out.
    If your bike has done quite a few miles I'd take the whole thing apart, check the bushes (the teflon on the slider is usually completely gone) and replace the seals and dust rings. I was a bit uncertain but it turned out quite easy to do.
    Jul 2004
    London N W
    Bike has only 4000m on it so any replacement parts should be unnecessary.Thanks for advice !
    africatijn Guest
    Hi,
    To Robels:
    Was thinking about doing a fork job myself as well.
    But, looking at the exploded view in the haynes manual, got a bit scared...
    You say it is not too difficult? Just open the buggers and see what happens?
    Cheers,
    Tijn
    Cotswolds, UK
    Quote Originally Posted by africatijn
    Hi,
    To Robels:
    Cheers,
    Tijn
    Had exactly the same feelings (I think it is rated a "four-out-of-five-spanner" jobby in Haynes) but it turned out to be quite a straightforward procedure. I have had bigger adventures with 3-spanner jobs like replacing the clutch . Just make sure to use a torque wrench, esp when you put the legs back into the yokes. Oh yes, and screw back the filler caps at the top of the legs before you tighten the top-yoke bolts, the legs are so thin they deform easily
  1. Aftermarket forks?
    By Taz in forum Varadero
    Last Post: 16-12-06, 07:55 PM
  2. not rd04 forks
    Last Post: 16-09-06, 10:00 AM
  3. Front forks
    Last Post: 08-06-06, 04:19 PM
  4. forks
    By tuggy in forum Africa Twin
    Last Post: 08-02-06, 10:57 PM
  5. Clattering forks??
    By transalpite in forum Transalp
    Last Post: 25-09-05, 05:59 PM
