Hi All , Im hoping the engineers amongst you, which appears from the job descriptions posted recently seems to be a lot, might be able to answer the following query: When my 99 @ is ticking over with no lights on the battery charges at about 12.9 volts going up to about 13.5 when the engine is revved, however as soon as the lights are switched on the charge rate visibly drops to 11ish. And when the engine is running with lights on, the lights do not brighten when the engine is revved. I would be grateful for any suggestions; Im tired push starting the bike cause the batterys flat.![]()
