Facet pump and charging
Results 1 to 7 of 7
Thread: Facet pump and charging
    Grumbleweed is offline Member
    Sep 2011
    NA
    Hi all, but of a techy one for you. Does anyone know how much ampage a facet draws in relation to the original Africa twin fuel pump?
    I just tested my voltage and all is ok, but not putting out as much as it was with lights on. I'm guessing the facet is drawing a little more current but would be handy to know how much!
    Has anyone got a voltage readout from a bike with a facet fitted? I'm just wondering if my reg might be on the way!!
    Re: Facet pump and charging
    I used to get between 13 and 14 volts from the battery terminals when revving the engine to about 2,000 rpm. That was with a Facet pump fitted and the standard pump.
    1 Varadero/34,000 miles ridden (of 57,000 miles on the bike), it's all still new to me!
    Sep 2011
    NA
    Is that with the lights on? Getting the same with lights off but 12.5 with them on at idle.
    Quote Originally Posted by Grumbleweed View Post
    Yes, with the lights on. It should be lower at idle, proves your regulator is working. Your lights should get brighter when you rev it slightly.
    Sep 2011
    NA
    Thanks for that! Bit of peace of mind!!
    Sep 2011
    NA
    Have just changed over my RR as this charging thing is a little worrying to me!
    Battery shows 12.5 volts with engine off
    idle with lights off is 13.5 and marginally rises when revved up.
    With lights on, at idle i'm getting 11.9 to 12.4. I have checked the fuses for corrosion and the earth strap which is fine.
    Without stripping the generator cover off, is there any other test i could do to see if the genny is cooked? Am going to France with it in June and dont really want to be stranded!
    GSPD750's Avatar
    Calgary, Alberta Canada
    [QUOTE=Grumbleweed;625133]Hi all, but of a techy one for you. Does anyone know how much ampage a facet draws in relation to the original Africa twin fuel pump?
    [QUOTE]
    1.6 amp average
  1. Facet pump
    By Grumbleweed in forum Africa Twin
    Last Post: 02-03-12, 06:44 PM
  2. Facet pump fit
    By gsdman in forum Africa Twin
    Last Post: 20-09-11, 07:47 PM
  3. Facet pump
    Last Post: 29-05-09, 07:46 PM
  4. Facet pump
    By PHILinFRANCE in forum Varadero
    Last Post: 06-12-08, 01:07 PM
  5. Facet pump
    By nigel page in forum Africa Twin
    Last Post: 27-07-08, 09:42 AM
