One more issue. The indicator switch usually won't register a left press on the first try and sometimes it takes five tries to get it indicating to the left. Indicating to the right works every time. Is this a common issue? Haven't opened the switch yet, but can it usually be repaired or should it be replaced?
Common problem, no big deal. Remove, disassemble, clean, use contact spray, reassemble, be happy.
Pics here: Wartung des linken Kombischalter der Africa Twin XRV750 RD07
Take some pics yourself, then you won´t be in doubt.
Tsuku (16-04-12)
