New AT owner with a few quick questions.
Results 1 to 10 of 14
Thread: New AT owner with a few quick questions.
    Tsuku is offline Junior Member
    Apr 2012
    Finland
    Hi y'all!
    New AT owner here. Bought a Y2K RD07A today. Pretty impressed with the bike (only driven it a few hundred km's so far). Have a few quick questions.
    1. Can you guys post a picture of a RD07A fuel tap? Mine doesn't look standard, I think it's been replaced. I guess it should be sitting flush on the outside
    but mine is right under the outlet in the tank. I have to reach inside the frame to use the tap. The reason I ask is because I can smell petrol when stopping
    at a traffic light or when I've driven it a while. An un-original looking fuel tap raised my suspicion.
    2. Coolant temperature needle. Where is it supposed to sit? I rode for good few hours today but the needle never rose more than a few millimetres above
    C(old). Granted, today was a pretty cold day (temperatures around 0 to 5 degrees celsius). Still, you'd think it'd rise further. Maybe faulty sensor? Wrong thermostat?
    3. Any ideas where to source a rear right footpeg with holder and all? There were tons of them for the left side on eBay, but none for the right.
    4. Know of any stores with a good price on a Leo Vince One slip-on?
    That's about it I think. Thanks! Here's a few pics of said bike: XRV 750 - pihled.kuvat.fi
    Paul-S's Avatar
    Jul 2007
    Runcorn, Cheshire
    Re: New AT owner with a few quick questions.
    Welcome Tsuku
    On your point no2 - there's nothing wrong with the temp guage they all run just off cold. The oly time I've seen mine up past the middle is in traffic after a long fast run and sometimes when offroad
    Can't help with the rest
  4. The Following User Says Thank You to Paul-S For This Useful Post:
    Tsuku (09-04-12)
  5. #3
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    An event Horizon somewhere
    Hi & welcome.
    Pauls answered No 2, so I'll take a stab at No 1, but without the picture.
    Yes, the original tap does come out to just about flush with the frame at that point. It is very easy to break the tap if the tank is removed without removing the tap, so it' is liekly that has happened to your machine at an earlier date. If you are smelling fuel, the fuel pet-cock (the bit attached to the tank) may have a leak due to perished / misaligned seal, possibly caused when the tap was broken. You'll need to empty and removed the tank to check this out, and your as well to have new seals at hand when you do, cos the old ones will probably not go back on (if they're not already broken ).
    Hope it's a simple tighten up job, which would be my first try at a fix, but you only know if it's worked once you've re-fitted and filled the tank
    Steve T
  6. The Following User Says Thank You to Steve T For This Useful Post:
    Tsuku (09-04-12)
  7. #4
    Apr 2012
    Finland
    Thanks guys!
    I'll look into the tap gaskets. I'm tempted to replace the entire tap with an original one if it isn't too expensive. That way I could turn the tap to RES while riding if the bike starts sputtering. Now I'd have to pull over to do that.
    Good to know that the coolant gauge is normal.
    Oh, just thought of another question:
    5. Is the choke lever supposed to be really stiff? It's very hard to operate while driving (with thick gloves) as the lever is so short and stiff. Maybe the choke cable could use some greasing?
  8. #5
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    1 - Fuel Tap is under the tank on the right side, and has a long plastic switch (#11 in the image below) over to the left side to switch between reserve, off and on. BE CAREFUL when removing tank as you'll need to remove this plastic handle BEFORE you remove the tank otherwise YOU WILL break it.
    2 - Already answered above
    3 - Rear Hangar and footrest - HAMART have secondhand ones in stock
    4 - Rugged Roads sell the Leo Vince LV One EvoII Exhaust for the Africa Twin in both Stainless and Carbon
    5 - Choke shouldn't be overly stiff - probably needs a clean - just be careful when removing the cable plungers from the carbs - the plastic body will probably disintegrate when you look at it - if it does, we have a solution
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    2008 - BMW F800GS - BumbleBee
    2003 - BMW R1150GS - Graphitan
    2002 - Honda Africa Twin XRV750 RD07A RWB
    1997 - Honda Africa Twin XRV750 RD07A Fast Black
  9. The Following User Says Thank You to Stormforce8 For This Useful Post:
    Tsuku (09-04-12)
  10. #6
    Apr 2012
    Finland
    Yeah, mine doesn't look like that anymore, which means somebody probably broke it and replaced it with a universal tap.
    Wow, thanks! I checked them on eBay before, but they didn't list that one on eBay. I quickly ordered it just now. Thanks again!
    Thanks, might order it from you guys, but not immediately since delivery can take 3 weeks and I'll be out of the country by that time.
    Thanks yet again. That looks really useful. Will probably order those just in case.
  11. #7
    Dec 2005
    If you want to replace your fuel tap with an original one.
    Hamart have a secondhand plastic handle - and there is an RD07A fuel tap on Ebay Germany.
    Rugged Roads
  12. The Following User Says Thank You to Stormforce8 For This Useful Post:
    Tsuku (10-04-12)
  13. #8
    nige is offline Junior Member
    Mar 2012
    yorkshire
    hi there, i too am a new africa twin owner 1998 rd07a. please send me your e/mail so i may contact you further. cheers regards nigel.
  14. #9
    Cookie is offline Toolbox
    Feb 2010
    Nieder-Olm, Germany
    Quote Originally Posted by Tsuku View Post
    I have an aluminum version of the LeoVince (version no. 7255) sitting on my shelf about to be put on ebay. One year old, about 2.000km driven, comes with an additional aftermarket heat shield (which is necessary to protec the boots). Actually its great but too loud for me (no kidding, travelling with my son as pillion I donŽt need additional growl to disturb communications).
    Send me a mail to detroitinfo at gmx.de and IŽll send you pics. 200 Euros excluding shipping; I can ship any day this week. Private sale.
    Chris
  15. The Following User Says Thank You to Cookie For This Useful Post:
    Tsuku (11-04-12)
  16. #10
    Apr 2012
    Finland
    Quote Originally Posted by Cookie View Post
    Chris
    Hey Chris,
    Darn, read this too late. I already ordered the LeoVince pictured above since I found it at a good price and with fast delivery. Thanks anyway! I'm sure you'll get rid of it fast on eBay.
  1. quick steering and lighting MOT questions
    By jarl in forum Mechanical Advice
    Last Post: 08-02-10, 06:01 PM
  2. New RD 03 Owner- questions
    By evilhomer in forum Africa Twin
    Last Post: 26-09-08, 08:01 PM
  3. New Owner Questions
    By Martin K in forum Transalp
    Last Post: 06-03-08, 12:13 PM
  4. Quick Questions
    By xrv_jim in forum Dominator / FMX
    Last Post: 15-09-06, 07:33 AM
  5. New Member and Owner. Questions?
    By DaveS in forum Africa Twin
    Last Post: 07-09-04, 07:33 PM
