Valve - Rocker Cover Gasket/Seal sweat ,engine out or can i ...
Results 1 to 10 of 10
Thread: Valve - Rocker Cover Gasket/Seal sweat ,engine out or can i ...
    raoulserban is offline Member
    Dec 2010
    romania
    i pushed my bike a lot and i rode it within 7000-7500rpm range at about 175kmh for quite a long period.
    after that i rechecked everything i done to it , and i observed that the valve -rocker cover seal sweats just a little oil. actually it looks humid.
    the big dillema is how can i change those seals without removing the engine from the frame cause those rocker covers dont get off cause of the frame
    AlanH's Avatar
    Bristol, UK
    Re: Valve - Rocker Cover Gasket/Seal sweat ,engine out or can i ...
    The rocker covers do come off with the engine in the frame.
    KTM 990 Adventure
    Dec 2010
    romania
    i tried to get them off at another rd04 and did not manage to get them off. i wanted them off so i could repaint them.
    if you did it then please tell me how! perhaps at rd07 you can get them outside the frame
    AlanH's Avatar
    Bristol, UK
    Well, they came out on both the RD04's I've worked on. You need to take off anything in the way (including carbs and coils I seem to remember) and then you will be able to get them out. The back one is tight and think you need to slide it forwards to where the carbs were before it'll come out. It's a while since I did it but it is possible.
    KTM 990 Adventure
    hotbulb's Avatar
    hotbulb is online now Senior Member
    May 2009
    Cardiff
    Mr Haynes says it's possible with the engine in the frame,but as Alan says you need to remove everything in the way (including a coolant pipe?)
    Dec 2010
    romania
    thanks guys, thats great intel!
    but ...hmmmmmm(the carb off and on, and the coolant...and so on and on).... i think i am going to let them like this(gonna clean the oily sweat each ride) untill i have the necessary nervs (new seals and new carb flange) to take everything apart cause i have dissasemblet and reassemblet the bike in the last month for a thousand times(i need to ride her more offten!)
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by raoulserban View Post
    For all the sweat your going to go through to replace the sweaty valve cover gaskets....it's just not worth it. Fugetaboutit....they all do that...they
    all sweat a little. It's not like it's a running leak. They are not an item you normally replace...in fact they can be reused once off with a little cleanup. Just ride it.
    Well maybe slow down a bit ...175 kph ...talk about stressing the old girl out.
    Dec 2010
    romania
    all right!
    but yet, i can imagine how you could get the front cover outside but what about the rear one? how do you get it off with that coolant steel pipe in the way
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    all right!
    Errrr, remove it.......
    The pipe is held in place with an 8mm headed stud, remove this & the pipe slides upwards out of the head (it's sealed with a rubber ring)
    As said - if it's only a bit damp don't worry about it. If or when you come to do the job tie it in with plugs, choke cable lube, carb strip & check, valves & coolant change.
    The cover gaskets do go hard & brittle with heat which is why it's always the rear of the rear cylinder that leaks, so will slowly get worse over time.
    As a thought, is your breather pipe from engine to airbox clear & not kinked?
    Sent from my HTC Desire S using Tapatalk 2
    '02 - 650 Transalp
    '92 - VFR750
    '91 - NC30
    (UK spec)
    '08 - 600 Hornet for sale
    (kind of....)
    AlanH's Avatar
    Bristol, UK
    You need new carb rubbers between the head and carb - unless you've already done it and the staining is old. Your clamps are also a bit wonky.
    As Phil says, take the pipe off (yes you need to at least partially drain the coolant).
    KTM 990 Adventure
  1. Replies: 6
    Last Post: 20-03-11, 07:02 PM
  2. Rocker cover gasket sealant?
    By rlkat in forum Varadero
    Last Post: 20-03-11, 04:42 PM
  3. rear rocker cover
    Last Post: 03-01-10, 07:55 PM
  4. valve/rocker cap needed
    By juscrooky in forum Dominator / FMX
    Last Post: 23-12-08, 03:17 PM
  5. Valve cover gasket (rear) leaking.
    By doglegdon in forum Africa Twin
    Last Post: 10-07-06, 08:43 PM
