18' rear wheel - Page 2
Results 11 to 20 of 22
Thread: 18' rear wheel
    AJsgp's Avatar
    AJsgp is offline Senior Member
    Aug 2007
    Sunny Singapore
    Re: 18' rear wheel
    Tank is fitted and tested for the fork as well...
    Jacquedup's Avatar
    Jacquedup is offline Senior Member
    Jan 2012
    South Africa
    Re: 18' rear wheel
    Hi, I am looking at replacing my AT front end with a front end from a 2005 YZ250F. Did you shorten the WR Forks, or just put them on straight? also did you change the springs?
    What did you do with the speedo?
    Thanks, hopefully I can get this project completed. Just alot of technical issues to investigate before I start.
  4. #13
    Jacquedup's Avatar
    Jan 2012
    South Africa
    Re: 18' rear wheel
    Also If i am reading correctly, you used WR forks with CRF clamps. Is this correct?
  5. #14
    Paul-S's Avatar
    Jul 2007
    Runcorn, Cheshire
    Re: 18' rear wheel
    Looking good AJ
  6. #15
    AJsgp's Avatar
    Aug 2007
    Sunny Singapore
    Re: 18' rear wheel
    Hi,thanks Paul.
    Yup,I fitted the WR4 top clamp,stem,and lower crf clamp(a mistake).
    reason,actually wanted to put both the crf top n bottom clamp together with the stem becoz the conditions of the CRF clamp is very new,and yes,becoz of theHonda logo on the top clamp.(very lame,i noe)
    ok,the outcome,I still do have a loose stem feeling,not good at the meantime,a slight knocking feeling upon heavy impact on potholes.
    As of today,I have successfully won the bid on a complete WR400 aftermarket triple clamp together with the stem.Gonna rework on it when it arrives.
    As for the WR400 fork on the AT,i did nothing much to it,and tested on a short offroad session,the speedo,I use the WR400 speedo along side with the wheel.IMO,it works brilliant.Height and ground clearance are great improvement,braking power,of coz,a little weak,but good enuff for offroad,not sure how bout for high speed highway riding.
    Till then..
    Ok,the 18' conversion will start somewher around next week or so.when the aftermarket triple clamp arrive.
  7. #16
    Paul-S's Avatar
    Jul 2007
    Runcorn, Cheshire
    Re: 18' rear wheel
    Thanks for the update AJ
  8. #17
    Re: 18' rear wheel
    You got yourself a trick AT! And the nature around you is something I could only wish for!
  9. #18
    AJsgp's Avatar
    Aug 2007
    Sunny Singapore
    Re: 18' rear wheel
    Hi thanks....
    ok,got the rim today...sized 2.50.
    Spokes being laced...
    Tomorrow in search of tyre....at presant,only can get 130 size michelin T63...
    Difficult to get the 140....was wondering,if 120 would be harmful for the AT?
    any feedback please?
    cheers
  10. #19
    Mr Beeza's Avatar
    Mr Beeza is offline Senior Member
    May 2012
    EU
    Re: 18' rear wheel
    Nice bike. But oh! that topbox!
  11. #20
    AJsgp's Avatar
    Aug 2007
    Sunny Singapore
    Re: 18' rear wheel
    As promised...the job is done...
    And next to the R1100R.
    and yes...finally bought this from Ebay and just arrived yesterday...will start doing it up next week.
  1. 650 rear wheel for 600?
    By basspete in forum Transalp
    Last Post: 04-07-10, 03:57 PM
  2. Replies: 2
    Last Post: 02-06-08, 10:08 PM
  3. 650 rear wheel on a '97 600?
    By teriyakimonkey in forum Transalp
    Last Post: 29-03-07, 02:07 PM
  4. 650 TA Rear wheel on 600??
    By ger in forum Transalp
    Last Post: 10-07-06, 10:38 AM
  5. Rear Wheel
    By in forum Africa Twin
    Last Post: 31-12-69, 11:27 PM
