Back brake caliper wobbly...normal?
Results 1 to 5 of 5
Thread: Back brake caliper wobbly...normal?
    621andy is offline Senior Member
    Sep 2010
    Germany, Turkey or Myanmar
    Front one is solid, but back one wobbles sideways if you grab hold of it...Bolts are tight
    Knew I shouldn't clean my bike...nothing but bloody trouble
    foz1969's Avatar
    Jun 2009
    Re: Back brake caliper wobbly...normal?
    there should be a little sideways movement, in the front calipers also. There are 2 rubber boots (self-sealing with the grease used so it can slide) & as the pads wear down, at least one of the boots kind of forms a vacuum that pulls the caliper back to the disc. When you service (clean) using grease & copper slip, on appropriate parts, you'll see.
    ”If you don’t have anything nice to say about people, come sit over here by me”
  4. The Following User Says Thank You to foz1969 For This Useful Post:
    621andy (30-06-12)
  5. #3
    angelo's Avatar
    Apr 2006
    West Wales
    Just went out to check mine - it wobbles slightly - less than a quarter of an inch. It's all set up correctly - I think this is the equivalent of the floating you have in the front disc.
  6. The Following User Says Thank You to angelo For This Useful Post:
    621andy (30-06-12)
  7. #4
    Farmboy's Avatar
    Farmboy is offline Senior Member
    May 2008
    In My Own World
    Yeah its perfectly normal, Disconcerting perhaps but normal never the less
  8. #5
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Wobble on mine to but to go one further if i push my bike forward slowly the brake judders, vibrates, buzz's cant find the right word but something like that
  1. brake caliper
    By kevsky in forum Africa Twin
    Last Post: 22-01-11, 09:31 AM
  2. honda cr 250 brake caliper, front brake assembly, cr250
    By Admin in forum eBay - CR/CRF/CRM
    Last Post: 18-01-11, 08:40 AM
  3. CRF 150 Front Brake Caliper
    Last Post: 10-01-11, 05:30 AM
  4. Front Brake - Normal??
    By nibs in forum Transalp
    Last Post: 08-06-10, 01:49 AM
  5. RD07 back brake caliper - adjustment advice sought
    Last Post: 02-02-07, 11:05 AM
