Fitting spot lights and 12V socket
Results 1 to 2 of 2
Thread: Fitting spot lights and 12V socket
    Jacquedup's Avatar
    Jacquedup is offline Senior Member
    Jan 2012
    South Africa
    Hi,
    I bought these spotlights and want to fit them over the weekend.
    it states on the package : Halogen Driving lights : H3-12V 55W
    I have bought a on/off switch, and the plan is to run wires from the battery through a fuse to the switch and from here to the lights.
    I have never done this before, so I hope this is correct. Please help me if i am going to mess anything up. Also what size fuse should I use. I hope these spot lights will work. They were a fraction of the price. I know the quality is not that great but i will replace them with proper ones once the money is there.
    I also have a 12V socket that I would like to fit, can anyone give me any pointers on this.
    Thanks....
    karl singleton's Avatar
    karl singleton is offline Senior Member
    Oct 2008
    derbyshire
    Re: Fitting spot lights and 12V socket
    Quote Originally Posted by Jacquedup View Post
    Hi,
    Thanks....
    hi
    55w x2 will be too much load for your generater to cop with, to charge your battery. i bought the same wattage spot lights and found the volt drop on your charging circuit didnot charge battery..
    i bought some solor led spot lights 0.5 amp per light and 55w output very bright..
    i mounted to crash bars with touratech mounting brackets..
    cheers karlAttachment 0Attachment 0Attachment 0Name:  Picture 026.jpg
Size:  133.4 KBName:  Picture 027.jpg
Size:  125.7 KBName:  Picture 028.jpg
    wiring using a 30 amp relay, live from batterry throught n o connection on relayAttachment 0Attachment 0Attachment 0Attachment 0 ,coil feed on relay, live feed taken fron rear lights then wired through switch on handle bars.. this means fog lights can only work when bike lights r on, and ignition on, so you cannot flatten your battery leaving spot lights on..
  1. Spot lights ..... battery low......
    By Tony Varadero in forum Varadero
    Last Post: 29-03-12, 11:23 AM
  2. 2allbuyer (Ebay) Led Spot Lights
    By HUDDERS in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 14-08-11, 09:56 PM
  3. Spot lights ..... again
    Last Post: 05-01-11, 03:43 PM
  4. spot lights on a african twin.
    By karl singleton in forum Africa Twin
    Last Post: 11-09-10, 06:23 PM
  5. Spot lights
    By PHILinFRANCE in forum Mechanical Advice
    Last Post: 17-08-09, 09:06 PM
