Results 1 to 10 of 32
Thread: H4 bulbs
    africatijn Guest
    H4 bulbs
    Hi,
    I am converting my headlight from the ancient bajonet connection to H4 bulbs.
    Only thing is how to connect the pins. There are 3 pins on a H4 bulb, one for earth, one for lo and one for high beam. Does anyone know which is which?
    I know how to test this, but, being very lazy....
    Cheers,
    Tijn
    posiwev is offline Senior Member
    Jan 2005
    heywood
    How have you managed to fit H4 Lamps into the Bosch Type headlamps or have you purchased complete H4 type lamp units?
    Andy
    jabba's Avatar
    Wow that is lazy
    africatijn Guest
    Right, quess I really have to do something about the lazyness...
    Will do an article about it when ready and tested...
    Cheers,
    T.
    jabba's Avatar
    Yeah is terrible!
    Think I will get up now
    africatijn Guest
    Of course... in this pace.. that article will arrive when all Africa Twins are completely gone/rusted etc.
    oh no, they already are...
    Planning is this weekend.
    12inch, its not beer you're having when getting up I hope? I does get you thru the day though...
    Cheers then!
    T.
    jabba's Avatar
    Oh yes fed straight to the arteries via a great big needle
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    And here's Tjin's article.... thanks for taking the time and trouble Tjin.
    http://www.xrv.org.uk/articles/headlight_conversion.php
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    modrover is offline Senior Member
    Mar 2005
    Washougal, WA USA
    Fantastic... I think I've now got all the bits to finally make my RD03 into the twin headlamp style (I've got the oddball single lens AT ). As cool as it might be to have that rare single lens... ATs look proper with twin rally lights.
    I'm going to be doing the H4 conversion as well. I might end up having a separate switch for one of the bulbs (with an off/on low/ on hi & low together). My bike is already wired for a single H4 bulb, but I don't feel the harness could handle powering two bulbs. I'll have to run wires from the battery to a relay and from the relay to the switch or, like I was saying, just run a completely sep. switch for the second bulb/lens.
    I've noticed that one lens is a bit different from the other... what lens was meant to be the low beam and which was the hi beam? I think I know, but thought I'd be dumb and just ask anyway... to make sure and all.
    I think it'd be sweet to run both H4 bulbs at once... I bet with both set to hi beam it'd light up the night like a comet! :P
    Any extra tips or info. on doing an H4 conversion would be welcome. I did read the Africa Twin H4 Headlight Conversion, but others might have found other tips and such that might be of help.
    Thank you.
    buggsubique is offline Junior Member
    Apr 2009
    New Zealand
    Re: H4 bulbs
    Bump! Sorry to bump up a very old thread, but I'm following the article and have done the mod but my lights are pointing too high now and my right (sitting on the bike) light has a really high dip. Bulbs have been installed with the correct tab bent to fit the notch.
    Basically the lows shine where they should but the right light shines higher up as well, and both high beams are very high - like a mile down the highway high. I seem to have already maxxed out the vertical adjuster wingnut (only have on on the bottom left) to bring them down.
    Any advice muchly appreciated!
    Cheers, Matt
  1. RD04 what bulbs?
    Last Post: 22-01-07, 06:15 PM
  2. XRV 750 INSTRUMENT BULBS
    By fw750x in forum Africa Twin
    Last Post: 10-12-06, 09:52 PM
  3. Headlight bulbs at Halfords
    By lootch67 in forum Chatter
    Last Post: 01-11-06, 11:28 PM
  4. Headlight bulbs
    Last Post: 16-11-05, 01:01 PM
