Check out the clutch switch on the clutch lever by unplugging it altogether or bypassing it with a piece of wire depending on if it makes or breaks the circuit to function. The bike should start in gear with the clutch lever in, so even if the bike thought it wasn't in neutral this should still work. The side stand switch should then be checked. The neutral switch is screwed into the crankcase somewhere near the front sprocket I think. Check the wires here, not easy as they are covered in cack.
