Results 1 to 10 of 10
Thread: Heavy man...
    fewtrees's Avatar
    fewtrees is offline Senior Member
    Aug 2004
    Cheshire
    Heavy man...
    I'm taking the AT over to Hungary in April and I've now put Touratech panniers on.
    My question is, how much weight i.e. Rider + Pillion + Luggage can you carry on the bike? I couldn't find anything in my Haynes manual..
    Plus when the bikes loaded up - How does it handle?
    gibbo is offline Senior Member
    New Zealand
    Fully loaded I weigh in at:
    Me = 100kg
    Pillion = 50 to 60kg (depending on mood)
    bike = est 210kg (incl. racks/bars etc, excl fuel)
    luggage = 40kg. This is from memory & includes tank bag + side bags, t.tech panniers, top box + tent strapped to top, couple of litres of water in platypus type bladders.
    All up 400 ish kilos. Probably way over any manufacturers spec. As for suspension, the rear shock is std with pre-load wound right up (probably still a bit too soft) and I have wirth progressive fork springs (+ the std short spring) & 15w oil. This seems to be a good set up for when loaded, there is minimal fork dive under breaking. Handling is surprisingly good although you need to plan your stopping distances a bit further in advance and keep cornering speed down.
    zorba is offline Mr
    Jan 2004
    Greece
    Vacations last summer...
    me, 110 kg
    wife, 65 kg
    bike 220 kg
    luggage, 30 kg
    I had 2 panniers with around 10 kg each and a top case with more than 10 kg...
    Handling is adequate for doing around 130-140 km/h but I have the fornt and rear spirngs changed to WP.
    Nov 2003
    Bournemouth Dorset
    I have had over 30 cans of cider plus camping gear, including a chair, hat and bog roll....
    Nov 2003
    Bournemouth Dorset
    PS
    I would load the bike up and take it for a run on all types of road, just to find out what load you are happy with.
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Who cares as long as you get there safely. Fab city.
    Stay out of the table dancing bars - massive ripoff so I'm told.......ahem!
    Ask for 'Old man's bar' if you want to pull (you didn't say if pillion was your missus).
    Chris J Barrett is offline Senior Member
    Nov 2004
    CHESTERFIELD
    Have you ever seen the way they load up a Honda C90 in Vietnam? If you work on that theory, Honda build quality etc. You should be able to get a small village on an Africa Twin!!!
    fewtrees's Avatar
    Aug 2004
    Cheshire
    Not sure about staying out of the table dancing bars. My pillion (friend) was a dancer so she might want to make a few bob along the way!
    She's also offered to model a xrv.org.uk T-Shirt if someone sends me a logo.. wet t-shirt style apparently!
    I think I'll have a practise run first, then see if I need to ask her to lose some weight
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quote Originally Posted by fewtrees
    I think I might turn in to a designer.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Re: Heavy man...
    Most bikes (from Honda C90 to Goldwing) have a recommended maximum carrying capacity of between 460 and 475 lbs. I guess there has to be a bit of a safety factor built in there too, so probably 500lbs total would be OK?
    Jim
    '95 R1100GS
    '80 XT250
  1. i wish i wasnt so bloody heavy handed
    By Chad in forum Africa Twin
    Last Post: 26-02-07, 09:04 AM
  2. Vara too heavy?
    By McVicar in forum Varadero
    Last Post: 27-08-06, 11:28 PM
  3. Heavy Duty Tubes
    By Lex in forum Dominator / FMX
    Last Post: 31-07-06, 10:01 PM
  4. Heavy Duty Inner Tubes
    By DaveS in forum Chatter
    Last Post: 22-06-06, 11:52 PM
