Having picked up my new (96) AT last week I spent all this week doing more or less a full strip down excluding the engine and have just come across my first problem.
I removed the front forks today renewed the fluid with 10 grade instead of 5, put them back in and dropped the yolks by 8mm to sharpen the steering up a touch, stripped and cleaned the calipers, renewed the rubber gaiters/seals, stripped the speedo assembly, re-greased it and then re-assembled the front end.
The problem is that the right side brake disc is contacting the right side caliper bracket. or to be more specific two of the four allen headed bolts that fix the disc to the wheel are contacting the caliper bracket. It's only very slight contact, you can freely rotate the wheel, but obviously there shouldn't be any contact. The other two bolts are almost contacting the disc.
It's as though there is a spacer missing but there isn't unless I'm very mistaken. The allen bolts on the left side brake disc are also only about 1.5mm from contacting the caliper bracket on that side. I can't believe that such a small amount of clearance is normal.
So unless I've mislaid a spacer when stripping down I'll have to find a suitable spacer to enable clearance. I'm pretty sure I've re-assembled everything correctly.
Any ideas?
