My speedo needle has started bouncing + - 10 mph and won't climb above 50-60 mph. Would I be right in assuming that it is the drive rather than the cable that is faulty and if so what part is required to repair it.
:beer:
:beer:
Check the tech data section, see the fiches.
You have to remove the front wheel anyway, so than you can also see what's wrong. Mind you, I could still be the cable...
Tijn
chances are it could be the cable and at only about £10 to buy and 2 minutes to put in i check that before looking at taking the wheel out. happened to my xjr for about a week before finallly breaking
The speedo on the @ isn't woth a carrot anyway. Compare it against a GPS & scare your self. Put it this way at a shown 80mph. youre doing 73!![]()
Stripped it down today, grooves on the plastic drive are worn smooth, replacement £16 from Honda.
What he said ....Originally Posted by Chris J Barrett
my AT seems to be 5mph slower than indicated at most speeds.. according to my GPS.![]()
