I'm looking for a set of panniers for my AT. Candidates so far:
- Oxford throw-over fabric panniers. They are light, no installation, 45l each, cheap;
- Givi plastic panniers. Look good, 41l each, lockable;
- Aluminium boxes (Zega or similar). Lower CG then the others, 41/35l, lockable.
It's seems that most of the owners go for the aluminium boxes as the most practical option, but what puts me off is that they are not symmetrical, which can be bad for the balance and high speed stability. Also, they are smaller than any of the other two.
Personally I like the Givi boxes most, but from what I've heard the pannier frame is a-symmetrical because of the exhaust, and this will cause the same problems as above.
As usual the cheapest option - fabric panniers - seems to be the best. The only problem is that they cannot be locked securely.
What's your experience? Can you post any pictures?
