Results 1 to 5 of 5
Thread: paddock stand
    garry is offline Member
    Jun 2004
    Hull,East Yorkshire
    paddock stand
    Any solutions out there ....I have just purchased a Motorax rear paddock stand c/o no centre stand on my 02@ ...however...have a scottoiler fitted and the flat supports on stand threaten to 'crush' the plastic tubing on the scotoiler. (fit under swingarm)..Thought of bobbins but dosen't appear to be anywhere to fit on the @.
    icenian's Avatar
    Jul 2004
    Votadinia
    I have the same problem. But ignoring it turned out to be a perfectly good solution.
    Pussyhorse's Avatar
    Essex mate
    Easiest solution is to move the oil feed line.
    A lot of people forget that installing the scottoiler line on the bottom of the swinger will cause problems when trying to use a padock stand.
    kiroh's Avatar
    Apr 2004
    London
    Another solution is to use the padock stand near the end of the swingarm where there is no plastic tubing.
    stueydo is offline bimbler
    Feb 2005
    notts
    I had the same problem with mine, all I did was to cut a groove in the padding to allow the scottoiler tube to sit in it without getting crushed.
  1. Paddock stands
    By markh in forum Africa Twin
    Last Post: 29-03-07, 06:11 PM
  2. Abba stand
    Last Post: 07-06-06, 11:21 PM
  3. Center Stand
    By Carport in forum Africa Twin
    Last Post: 08-02-06, 11:41 AM
  4. Center Stand
    By Paul P in forum Africa Twin
    Last Post: 13-01-06, 11:27 AM
  5. Paddock Stand
    By Dave in forum Africa Twin
    Last Post: 15-06-05, 11:49 AM
