I have been having the most ridiculous time with White Bros. of Darlington. I posted a topic on here ages ago about being unable to start my AT and got lots of responses. The theme of them was that it was likely to be a problem with the choke and plungers. So I took the choke cable off and oiled it all up, freed up the little choke lever and generally made a good job of it. However, on re-fitting it I broke the plastic fastening that fixes the cable end to one of the carbutettors. My fault, so I went to White Bros for a spare. I was told that I needed a complete choke cable. However when that arrived, I had to point out that there was no fixing on the end. they said it was the wrong cable and would re-order. When the replacement came, it was identical. Then they had a closer look at the microfiches/ Honda website and decided they had now identified the part needed. When that arrived, it turned out to be the flexible weatherproof plastic sleeve over the cable end. Then they realised that the part needed was on the diagram for the Carb not the choke cable (I took the old part to show them a couple of times but fat lot of difference it made!). The fixing came with the plunger and spring so it was unneccessarily pricey £20!. When it arrived, it turned out that what had been ordered by mistake was the slim bolt with the thumb wheel for adjusting the idle speed. So I stood over them whilst they sorted out the right part number and they got that ordered. Except they did not. I called in today and they had lost the order and nothing had been done about it. I prepaid so that was outragously incompetent.
What is the point of buying overpriced spares from a dealer if they cannot give good service and advice? My bike has not been able to be used for 3 months now and the problem is still not resolved. I'm a big grown up boy with a science degree and working in technology transfer. What I want to be able to do is to identify the part number from a diagram and place an order on line and have it delivered direct. This would cut out the dealer margin which is fair enough given the lack of added value that they have provided. Any one know if this can be done. David Silver seems to offer big bits but not the fiddly stuff. All I want is 20pence worth of plastic. (I work with automotive OEMs so I have some idea)
I bought the bike because it suited me and it was cheap. It needed work but I thought I could ride it and improve it as I went. The way I feel tonight, I just want to get rid of the thing asap.
