If like me you do all your own mechanics, you will know how bloody irritating it is trying to bend your feeler guages down through the inspection covers and into the valve clearance gap. I'll give you a tip, take off the rocker covers. It's a lot easier & you can get you clearances bang on. The back one just lifts straight off but the front one you have to remove the coil & just raise the cover enough the get at the valves. Do not try and pull it clear or you will knacker the seal. This way doesn't take any longer and I find it a lot more accurate.
