Results 1 to 4 of 4
Thread: Sprocket Update
    Dave's Avatar
    Dave is offline Senior Member
    Reading
    Sprocket Update
    Hi
    I posted a note recently stating that Twiggers Motorcycles in Loughborough could get a replacement 17T front sprocket for the AT. Turns out that this was the case but their supplier has stopped making them so it's no longer an available option.
    I noted that a couple of you run 40T rear sprockets - have you had to shorten the chain or are the adjusters able to take up the slack without any problems?
    Regards
    Dave
    Northy's Avatar
    Northy is offline Senior Member
    Jul 2004
    S.E. KENT
    I'm running 40 t rear and I think I removed two links from my chain....( the brain cell can't remember).
    I sure there are companies that will make up new sprocket ... Just can't remember ( that brain cell now gone totally to sleep) ..... I'll have hunt tonight (to see if I can find the other brain cell )
    Northy
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Mine's been running a 40 tooth rear since I got it, don't know if the chain has is shorter but I suspect so - it's only on position 8 on the adjusters.
    Jim
    '95 R1100GS
    '80 XT250
    Northy's Avatar
    Jul 2004
    S.E. KENT
    Hi got my brain into gear try http://www.bandcexpress.co.uk/
    They list the 40 t rear for the @ they may be able to do 17 front.
    Never used them my self so if you do lets us know how you get on . Front spkt easier to change the than the rear ( cheaper too )
    Northy
  1. handlebar update
    By redmarcus999 in forum Varadero
    Last Post: 22-06-06, 09:54 PM
  2. Frankendom update 3
    By anton88 in forum Dominator / FMX
    Last Post: 02-05-06, 06:23 PM
  3. Frankendom update
    Last Post: 20-04-06, 09:51 PM
  4. Another Frankendom update
    Last Post: 20-04-06, 09:49 PM
  5. Update
    By DaveS in forum Chatter
    Last Post: 07-12-05, 06:22 PM
