Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 38
Thread: RD07 AFRICA TWIN AT 118,000 MILES
    Chad's Avatar
    wickford,essex
    strewth here i am looking to by an AT trawling through the adds , getting worried because i cant find any with much less than 25-30,000 on the clock . more power to you fella you are either an ace mechanic or these bikes are bloody indestructable. i cant wait to sell my bandit and get me one !!!
    jabba's Avatar
    yes yes do it you will never look back my 1200 used to eat chains, tyres sprockets, petrol ,boy racers and bearings of any type and description.
    And yen really 85mph what an example your setting tut tut
  4. #13
    Roy
    Roy is offline vodka tester
    Feb 2005
    Ludlow (all settled!)
    spot on...have to agree with the comments...
    i have had mine 2and a half years now...bought it with 47,000kms on the clock, it has been past the 100,000 and is now up to 89,000 again!
    it looks like a nail but goes fine, (its a 1989 RD03 with an RD07 lump in it)
    dropped it in for MOT last week...at the normal place it goes...he looked at the back tyre and commented..."bit close bit will let it go" then said hang on only fitted it 7 weeks ago......so he checked he was wrong! i have done 14,000 miles in the last 8 weeks....
    faults ?
    spokes 2 sets in 2 years (back only)
    tyres every 12,000 plus
    ignition coils twice
    couple of oil leaks
    4 sets of chains and sprokets
    one back disk, 4 fronts (twin disk)
    head bearings (one set)
    clutch cable
    choke cable
    speedo drive and front wheel bearings, and back
    bulbs now and again.....
    not much else.....
    have to agree, cracking piece of kit !
    seems to eat heated grips though ! (4 sets) always does 40mpg plus
    Roy
  5. #14
    Quote Originally Posted by chad
    I have a record player in my garage, the secret to good bike maintenance. Plenty of heavy metal and lots of tea, spanners are of secondary importance.
    ps my bike has less than 25,000 'on the clock', one careful owner LOL
  6. #15
    Chad's Avatar
    wickford,essex
    well guys you have got me convinced. im gonna get my AT install some heavy metal in the garage next to the pink floyd and fleetwood mac put a kettle next to the beer fridge . cant wait !!!!!!
  7. #16
    jvaughan is offline Senior Member
    May 2004
    Andover, Hampshire/ London/ South Wales
    Good reading. My Bike has just clocked 10,500 miles. I know she is good for a few years yet
  8. #17
    Re: RD07 AFRICA TWIN AT 118,000 MILES
    Quote Originally Posted by YEN_POWELL
    Well, I’m bored and stuck at home so I thought I’d do an ‘Africa Twin at 118,000 miles’ thing. It’s all the rage at the moment.
    I bought the bike new in March 2000. It’s been taking me to and from work (100 mile round trip) ever since then. It’s also taken me to Brittany, Morocco, Spain and Portugal, as well as numerous rallies/events. It’s never failed any of it’s 3 MOTs (yet) despite having the original (wafer thin) rear disc.
    Fuel consumption, highest 58mpg, lowest 41mpg. Currently averaging at 49mpg during my ride to work, which these days is almost all straight 85mph cruising with a bit of town work at the work end (London, I think the place is called). I estimate that something like 2,408 gallons have flowed through the as yet unreplaced fuel filter and into the carbs. I still got banned from my local petrol station for refusing to remove my helmet though….
    I’m checking my valve clearances approximately every 15-20,000 miles these days and it’s rare to have any needing adjustment. The same goes for carb balancing, as these too rarely go out of kilter. Sparkplugs get replaced every time I check the valves, although the removed ones look like they’ve had an easy life. In fact I replace headlight bulbs more frequently than sparkplugs these days, possibly a vibration problem somewhere in the headlight mountings.
    I had Tony Galea put a pair of new camchains in at 70,000 miles because of an alarming engine noise and for my own peace of mind. Turned out the old chains were still pretty good. The noise turned out to be one of the deep seated plugs unthreading itself and allowing pressure to escape. I did feel stupid when I worked it out. Apart from the camchains, all other maintenace has been done at home. I hate bike shop mechanics, untrained monkeys 90% of them. The other 10% are really good, but I never seem to meet any of those ones.
    I opened the clutch up at 83,000 miles and filed the grooves away on the clutch basket. These had been causing a bit of judder on fast pull aways. I checked the springs and plates and they were all within tolerance, but seeing as I was in there anyway, I put new Honda friction plates in. I kept the new springs for another day or another Africa Twin in the future.
    I greased all the rear suspension linkages at 50,000 miles and have not touched them since through laziness. I’m expecting to replace them if they seize or corrode as they’ve lasted much longer than expected. I’m still on my second set of head bearings which were replaced with OE items at about 80,000 miles. The rear wheel is on it’s second set of wheel bearings which were replaced before my Morocco trip (50,000 miles) and spent a lot of time immersed in water. Despite this, the replacements are still looking good at each tyre change. The replacements had extra grease placed in them before fitting. The front wheel bearings were replaced this year as a precaution only.
    Both front and rear wheels are extremely corroded inside but no spokes have loosened since they were replaced with stainless items at 50,000 miles, so I’m sticking with the wheels in the hope they’ll last longer.
    I’m currently running Tourance tyres for the first time (don’t know what every one raves about, they seem pretty average to me, still waiting to see mileage achieved with them. Apart from the OE T66s I’ve only used Bridgestone Trailwing 101/152, as they seemed to wear well if having no other good qualities. The Trailwings averaged out at 12,000 miles for the front and 12,000 miles for the rear. I’ve suffered 3 punctures in the last 118,000 miles. One was a 90mph bum clencher, when a nail ripped the inner tube to pieces. The second was a huge nail from a burnt pallet I rode over on the last mile (on a local green lane) back from Morocco whilst shod with Michelin Deserts (alright, very nearly always Trailwings). The third was a front blow out caused by my own repair patch coming adrift. The bike was just about rideable for the mile or so it took to find a verge to repair it again. Since then I’ve never used a patched tube. It was a lovely day for a breakdown though, sunny evening in the country, even a convenient pile of engineering bricks to prop up the bike on whilst the front wheel was out.
    I’m on my 3rd fuel pump. The first 2 OE Mitsubishi electric items all went Pete Tong at 40,000 mile intervals. The current replacement is a Mikuni vacuum type originally designed for microlights. The only problem it has caused me has been on two separate really hot days when the bike cut out at motorway speeds then started again when cooled down. I believe this was caused by the pump being bolted directly the engine, so it has now been ziptied to the frame to see if this problem is cured. Time will tell.
    Exhaust corroded away very recently at 110,000 miles. It was replaced with a Pro-Duro road silencer. Definitely goes a little better though I suspect this is more to do with there being no leaks from corrosion anymore.
    As mentioned previously, the rear disc is still original. The fronts warped at 65,000 miles and were replaced with EBC discs. These are cr*p with the recommended EBC pads in the wet, a form of ABS in fact. But I’m too tight to change them so I’ve tried a few different pads and ended up with DP motocross pads which work brilliantly in all weathers and last nearly as long as the EBC.
    Right that’s all I can think of. I hope you’ve been paying attention at the back because I SHALL be asking questions later on.
    NEXT WEEK- A brief history of DR350 wheel bearing changes (11 pages)
    update 128,000 miles
    Now on 4th fuel pump, a new 99 version Honda OE (cheaper than the 2000 updated one and lasts the same amount of time). Also still on original rear disc. Front brakes sticking a bit, pistons and pins fine, so new seals time I think. Still ticks over perfectly and quietly. Using oil now but not smoking. Did a test over the last litre used and it did 1100 miles for that litre, not good but actually within Honda's criteria for a new bike not to have a warranty claim. Fixing the leak from the rear tappet cover might help reduce it a bit. Play has appeared in one of the rear suspension bearings, the one I didn't grease in 2002 cos the centrestand was in the way I reckon.
  9. #18
    Chad's Avatar
    wickford,essex
    man that bikes a living legend keep up the good work yen
  10. #19
    boboneleg's Avatar
    Bristol
    Hey Yen
    pity your cacks don't last as long...
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
  11. #20
    Quote Originally Posted by boboneleg
    Hey Yen
    Actually, they have a higher mileage!!
  1. New Africa Twin...
    By Breeze in forum Chatter
    Last Post: 29-09-06, 12:56 PM
  2. THis Africa Twin looks a bit low
    By Shep in forum Africa Twin
    Last Post: 13-08-06, 04:59 PM
  3. The New Africa Twin!
    By LaughingBob in forum Chatter
    Last Post: 24-01-06, 08:13 PM
  4. New Africa Twin...
    By Adjani in forum Africa Twin
    Last Post: 01-01-70, 05:20 PM
