Hi guys.
I'm looking for a bit of technical help as I attempt to get my AT ready for an MOT following some time on south America's roads.
I rearranged the front end of my AT in southern Chile earlier this year causing damage to the frame at the bottom of the stock where the lower bearing is housed. The old bearing was shattered and some of the fragments were encrusted into the frame. All very alarming. The fix at the time was to reshape the stock and fill the new holes with some weld. The original bearing would not seat in the housing as Honda had intended so a conical needle roller bearing was fitted. Finding a suitable one was a mission and I had to resort to one with the correct outer diameter and machine the inner to fit the stem. This fix got me another 15000 miles but now the steering is not what the MOT tester would approve of.
After this long winded description, the question is where can I get another bearing to do this job? What size do I need? I don't really want to take the bike apart without the new bits nearby gagging to go on.
Hope someone can help. Great to join the site at last.
Cheers,
Matt
