Results 1 to 6 of 6
Thread: Help, electrical problem
    clbuff is offline Junior Member
    Mar 2005
    Caracas, Venezuela
    Yesterday I was for about 20 minutes of riding when the motorcycle stall and I had turn on the reserve as usually do when I´m out of gas, but I have more than 3/4 in the tank, when I looked to the instruments the tripmaster was out (no numbers at all), the tachometer was working and the engine was running intermittent, I´d shoot the engine off and when I´d turn again the ignition key all the lights were dead, suddenly they came on and the bike start again but erratic, I´d try everything to try to have the engine on and I don´t know why but when I´d turn the lights on the engine regularize, what´s the problem?
    thanks for your help,
    Claudio
    Caracas, Venezuela
    zorba is offline Mr
    Jan 2004
    Greece
    Classic...
    It is a loose battery connection
    DaveS's Avatar
    DaveS is online now Ex XRV Site Owner
    Nov 2003
    Bristol, UK.
    Yep I'll second that.
    Damned frustrating, but an easy fix once you know.
    Remove the seat. Undo the bolt attaching the plastic cover to the battery compartment and then reattach / tighten the lead. Apply some thread locking compound if you don't want it to happen again!
    Job done.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Mar 2005
    Caracas, Venezuela
    sorry but not an loose terminal, I´d already try that
    zorba is offline Mr
    Jan 2004
    Greece
    Try cleaning the terminals with WD40 and scotch bright, maybe it is a bad connection.
    Try by-passing the ignition switch. Mine had similar symptoms and needed a new switch. See other posts for a cheap alternative to the Honda ignition switch if that is the problem.
  1. Electrical Gremlins
    By z-weiser in forum Africa Twin
    Last Post: 09-08-06, 04:08 AM
  2. Electrical problems on AT
    By dalec100 in forum Africa Twin
    Last Post: 22-02-06, 01:46 PM
  3. Electrical Defeat
    By paultheold in forum Africa Twin
    Last Post: 14-11-05, 07:30 PM
  4. Electrical Problem - can anybody please help
    By Hibbo in forum Africa Twin
    Last Post: 15-10-05, 09:27 AM
  5. HELP...ANOTHER ELECTRICAL PROBLEM
    By SHARPY in forum Africa Twin
    Last Post: 31-05-05, 04:10 PM
