Results 1 to 10 of 17
Thread: Replacement Trip Computer
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Well seeing as my Digital Trip seems to have gone belly up and due to the fact that I rely on it, I was looking for a replacement.
    I then came across this!
    I want one, and I want it now! £59.99 for the kit.
    http://www.trailtechproducts.co.uk/store/computer.htm
    Anyone seen anything similar that compares?
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Jan 2005
    Netherlands
    Well, these compare but only with the functions, not the price
    http://www.icoracing.com/cm/cm1.htm
    markh's Avatar
    markh is offline Senior Member
    Bedfordshire
    How reliable are these magnetic sensors, though? I have not had good experiences trying to use cycle ones on my (former) XT600 - they seem extremely sensitive to sensor positioning. Admittedly the photos at that site look like the fixing is pretty solid, but wouldn't it be better to have something that plugged into the speedo drive?
    I am tempted, though, as I have a KPH speedo and trip computer, which is a bit of a pain. I haven't had the courage to take the trip apart and do the MILES resistor mod yet! I also couldn't find mention of a specific XRV fitting kit, or did I miss that?
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    I've seen a lot of trail bikes and converted motox bikes that use the Trailtech computer. If it works off-road then it's a fair bet it'll be okay on-road. Go for it, take photos, post a report!
    Jan 2005
    Netherlands
    I use a Sigma BC1200 bike computer on my XT 600 and have a other one lying ready to fit on my AT.
    The BC1200 has a function called NAV/PLUS. This is a tripmeter setting that can be reset with a touch of the reset button. The buttons are extended to the indicator switch. Left signal is to scroll through the menu's, right is reset.
    For my AT the buttons will be made on a small plate under the horn button. Not a priority at the moment so can take a while before i fit it.
    This is the set up on my XT.
    Signal comes from a small magnet on a spoke. No problem with it up to now. The speed and distance is almost the same with the GPS V. The original speedo is very good too i discovered with the GPS.
    Blues N Twos is offline Senior Member
    Feb 2005
    Amersham Bucks
    I think for the price Dave you would be foolish not to give it a go. Second hand trip meters on ebay seem to fetch £100 now and then. It looks neat as well.
    Good luck if you plump and let us all know how you get on.
    Jon
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    I've mailed them to find out which fitment I should order.
    That's assuming they know which one will fit an AT.
    I am very very tempted though and will probably try to make one fit either way!
    2010 KTM 450 EXC-R
    Simon Guest
    Quote Originally Posted by markh
    Taking the trip apart to do the work is really simple and i did it in work in no time. By doing the mod it will display digital kph. It won't let you change to MPH even but removing or adding a resistor at the mile part of the circuit cause i tried.
    http://www.atic.org/faq/tripmaster.html
    This will show you how the do it.
    Grader's Avatar
    Grader is offline Member
    Jul 2005
    Epinal, France
    Dave,
    I have fitted the TrailTech Endurance on my Yamaha WRF400 Enduro bike. I haven't ridden that much with it yet but it has been ridden round a motocross track (including suspension bottoming jumps) for about an hour with no ill effects as well as various road and trail rides. When I was in the US (California) I had a friend who had one (or something very similar) on his YZ250 and he used to race and ride every weekend with no problem so I don't think there should be any question of durability assuming the part is installed correctly.
    The sensor mounting is much beefier than a mountain bike speedo and if I remember right I had to drill a hole in the mounting area of my brake caliper to bolt the sensor onto.
    The preferred pickup is to replace one of your disc bolts with the magnetic one supplied in the kit, if this is not possible then I think there was another magnet supplied that could be attached to the wheel spokes similar to a mountain bike setup.
    With the disc bolt setup I think the system is very robust so my advice would be to check the thread on the AT front disc bolts and make sure to order a kit with the same replacement bolt thread.
    I believe there are generic fitment kits for this speedo for both USD and regular forks maybe these would be the best bet.
    The standard handlabar mount for the display unit is a bit flimsy but I suspect you would want to fabricate a new bracket anyway to mount the unit in place of the Tripmaster.
    I'll try and take some pictures of the installation tonight if you're interested to see more.
    Also I've found a scanned version of the instruction manual which I'll email to you separately.
    FYI this part costs $80 in the US, not sure about delivery cost.
    https://www.electrosport.com/electro...edometers.html
    https://www.bajadesigns.com/NET/main....aspx?content=
    Cheers,
    Chris.
    zorba is offline Mr
    Jan 2004
    Greece
    If you are interested I have a trip computer that rything in miles, but the screen is damaged by some solvent and is not readable very well.
    Still, it is in perfect working order and yours for 50 EUROS + postage, paypal only.
    Let me know
  1. Computer Backlight
    Last Post: 26-06-06, 12:40 PM
  2. Replacement A/T
    By piguglyshandydrinker in forum Africa Twin
    Last Post: 04-02-06, 11:03 AM
