Results 1 to 3 of 3
Thread: Hints and Tips
    Hints and Tips
    Okay, add them here as you think of them,
    Do you seem to go through clutch cables quite quickly? Do they unravel or break at the clutch end? Do you tell people it's cos you're such a hard riding biker, the cable can't take it?
    Look at the bracket that holds the last part of the cable. If it is slightly twisted the cable inner saws itself against the cable outer. A bit of gentle bending so the cable inner emerges dead straight will add years on to the life of the thing.
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Don't assume anything electrical is knackered until you've taken it apart and cleaned it, especially anything that looks coppery or brassy and has a wire attached.
    I had the rectifier, starter motor and battery priced up and almost on order till Robelst pointed out the now obvious, the copper studs on the starter solenoid aren't supposed to be green are they!
    I really should know better, my brother trained as an auto-electrician and spent his whole apprenticeship stripping starters and the like de-gumming them and putting them back together
    Nov 2003
    Bournemouth Dorset
    Always use "never seize" or "copperslip" on any nut bolt ect before reassembly. When putting front or rear wheel back on your bike put plenty of HMP grease around the dust seal, it helps stop the ingress of water and dust.
  1. TIPS
    By JUNCTION in forum Chatter
    Last Post: 28-04-06, 03:18 AM
  2. ANY TIPS OR ADVICE
    By mudplug in forum Chatter
    Last Post: 24-04-06, 09:54 AM
  3. any tips for staying dry?
    By africatijn in forum Chatter
    Last Post: 25-11-05, 07:42 PM
  4. Top Tips
    By DaveS in forum Chatter
    Last Post: 04-02-04, 04:34 PM
  5. TIPS
    Last Post: 01-01-70, 11:28 AM
