Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Fork'ing Hell !!! Fork Rebuild Questions!
  1. #21
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Re: Fork'ing Hell !!! Fork Rebuild Questions!
    Quote Originally Posted by xrv_jim View Post
    Easy. Get a Haynes manual. You CAN do it!!!
    Pattern parts can be OK or can be cr*p while the Honda parts do have implied quality. While replacing seals is easy it's not something you want to be doing again and again...or are you some sort of masochist £25 + VAT seems like a lot for oil seals but I think I'd go for it.
    I put 10w oil in mine and dropped the forks 10mm up through the yokes. I works for me but I guess any weight of new oil is going to make a big difference to the grey sludge that's probably kicking around in your fork legs now.
    Finally, you will feel a warm glow after doing your forks. This will probably the satisfaction of having 'done it yourself' and cheating a paid mechanic from doing the job...or an adverse reaction to grey sludgy fork oil that you've covered yourself in
    About 10 w oil , a mate of mine who's a mechanic told me that if I use 10 w oil it wont pass the oil seals as easy as 5 w oil , it 's a bit more viscous.
    Going with it as my bike when its finished will be a low miler .
    Jonny
    AlanH's Avatar
    Bristol, UK
    Choose the oil weight according to the damping characteristics you want. Don't put thicker oil in an attempt to stop fork seals leaking. If the seals are shot, it's true that 10w will leak out slower than 5w but it will still leak out and the seals will still need replacing.
    If your mate is a motorcycle mechanic, don't let him wok on your bike
  4. #23
    Wingnut's Avatar
    Sep 2009
    Ireland
    Ok
    All went well . Got both oil seals and dust seals in - biggest problem was getting that barstuard guide bushes into their locations. Didn't like hammering at them so I took the gap out of them by hand squeezing them until there were closed and tapped em in very gently with a hammer and flat head.All in all seam to be good.
    Have to say thinking about it should have bought the more expensive seals any way rebuild under way.
    Also replaced the points in the fuel pump seams like the most economical option given the price of a new pump.
    Later
    Jonny
  5. #24
    jokey's Avatar
    jokey is offline Junior Member
    Apr 2009
    Greece
    NOVEMBER 07
    from a rebuild of an ax1 250
    look at the hand made tools he use to put back the seals
    I think it is almost the same
  6. #25
    Wingnut's Avatar
    Sep 2009
    Ireland
    Started the rebuild and started at the front .
    forks - Oil seals and repainted all components.
    Started on the breaks this evening .going to have to use the stud extractor's , allen head on one of the pad retaining pins in rag order , giving it a soak with WD40 OVER NIGHT.
  7. #26
    husky_jrh is offline husky_jrh
    Jun 2007
    Oxfordshire
    MODERATOR EDIT: For Sale details removed. Please subscribe to use the WANTED/FOR SALE area of the forum.
  8. #27
    paulc's Avatar
    paulc is offline Senior Member
    Nov 2009
    Carshalton,London, United Kingdom
    lil tip when you undo the top of the forks undo the fork retaining bolt at the bottom too and do remember to take the oil out first, then just let the fork assembly (with a little help from you)pop the seal out.
    To repeat what already been said on here be very careful putting the new seals in, useing a pipe with the right diameter makes it a doddle.
    Have fun Paul
  1. RD04 - what the hell is this !!
    Last Post: 17-11-06, 09:32 PM
  2. What de hell is dis?
    Last Post: 17-07-06, 07:44 AM
  3. what fork springs or fork mods?
    Last Post: 05-04-05, 08:13 PM
