Results 1 to 9 of 9
Thread: Choice of battery
    Richard is offline Member
    Jan 2005
    Scotch Corner
    Choice of battery
    My AT is fitted with a Sprint battery that is starting to loose its chrge quite quickly so it needs to be replaced. Even when it was fully charged (i.e. after a long run) the cranking speed is pretty poor. Terminals have been cleaned but made no difference.
    So what is a good battery for delivering loads of amps for starting? Someone told me that Gel-filled batteries are better.
    Richard
    jvaughan is offline Senior Member
    May 2004
    Andover, Hampshire/ London/ South Wales
    Gel are good.
    You used to beable to buy sulphuric acid to replenish motorbike batterys.
    I have done it a new times... wash with deionised water and top up with Sulphuric Acid. Charge overnight.
    Cotswolds, UK
    Yuasa make good batteries. Got one in the AT and in the Buell, none of them are gel-ones. The Yuasa in the Buell is 4.5 years old, pressed the starter after 3 months of not running: the lumpy big engine started without the slightest hesistation. That's good enough for me
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    I replaced my ailing battery with an OE spec one (I think it's a Yuasa?) - anyway, it's acid filled, sealed for life and doing it's job.
    What's the big advantage of gel batteries?
    Jim
    '95 R1100GS
    '80 XT250
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Quote Originally Posted by xrv_jim
    They be made with extra special electrickery magic, supposed to hold their charge better and are slower at eating your foot away if you drop one on the floor!?
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    I had one of those gel batteries in my Beemer, it sure turns the motor hard and quick. Only problem I found that in the cold if you have problems starting a bike it runs down much quicker than an acid battery and they go completely flat.
    With the old acid batteries they tend to regain some charge if you leave it for a couple of minutes - the gell does not seem to do that.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Hmmm!
    The only experience I've had with Gel/Maintenance free batteries were bad ones, up until the point when I bought and permanently started using an Optimate, whilst the bike was being stored/not used.
    In the space of 3-4 weeks, the battery was being completely drained by the alarm. A re-charge with anything other than an Optimate (even expensive Halfords intelligent chargers (do those two words go together?!!) which is the only charger I use now, seemed to cook the battery and it either recovered briefly, or never recovered.
    These experiences weren't with an AT, but something of Italian origin, however I have to say that the bike and alarm (Datatool) were not at fault, it was always the battery. They just can't seem to handle the small but constant drain of an alarm.
    Stick with the original battery. At £23 they're cheap as chips, and last well enough.
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Quote Originally Posted by BobA
    Halfords intelligent chargers (do those two words go together?!!)Bob
    Ohh Bob how you made me laugh and laugh this morning, nearly spilled my cuppa all over my keyboard when I saw that combination - Halfrauds suck
    BobA's Avatar
    Sussex Riviera
    Maverick
    You were having a cuppa this morning!! Jeeezus, it was such a nice day I thought you break out the Bri !!
    Best Wishes
  1. Jacket choice
    By Mudwiz in forum Clothing
    Last Post: 03-01-07, 01:04 PM
  2. Armour choice
    Last Post: 25-12-06, 08:11 PM
  3. tyre choice??
    By shaneh in forum Chatter
    Last Post: 02-11-06, 08:15 PM
  4. A Choice of Boots
    By Taz in forum Chatter
    Last Post: 17-02-06, 05:13 PM
  5. again tyre choice...
    Last Post: 08-11-04, 05:35 PM
