Results 1 to 3 of 3
Thread: Goodridge brake lines
    icenian's Avatar
    Jul 2004
    Votadinia
    If you're thinking about fitting braided brake lines, do it now!
    Finally fitted them on Sunday. What a difference! Have fitted braided lines on other bikes and never been sure they did a great deal, but they are definitely worth it on the AT. They still feel rather wooden, but you start to get reasonable stopping power without having to grip really hard, so you get better control; and with a good tug on the lever there is more total power.
    This effect isn't because the brakes were in a poor state beforehand (i.e. a simple change of fluid etc. wouldn't have done this). I actually fitted new pads, cleaned up the calipers, changed the fluid and bled the brakes a little while ago (when I was going to fit the Goodridge lines but found I had the wrong set), so I didn't do a full overhaul this time. The only possible confounding factor is the switch to syntheic DOT4 fluid - that may be more reistant to fade and may possibly last longer, but I doubt it is resposible for the immediate improvement in normal braking I have got now.
    Dave S gioves great photos of how to fit Goodridge brake lines in this old thread. I did mine the same except:
    • at the top yoke, just below the master cylinder, I totally removed the existing bracket and fitted a P clip
      on the bottom yoke I reused the two wee brackets that held the rigid part of the OE brake lines, as DaveS did, but I swapped them round and also fitted the one on the right (originlly on the left) upside down; this just moved the splitter on the Goodridge brake line a bit higher up, as there seemed to be a great excess on brake line to the right caliper (YMMV!)
      I'm a cheapskate so I bought some s/s P clips rather than the nice alloy Goodridge ones (check out dallasmarine2002 on ebay, pack of 5 stainless steel 6mm p clips for 3.75 incl. postage)
      To secure the Goodridge splitter or a P clip to the bottom yoke (depending on whether you leave the brackets as they are or swap them round like I did) you need one nut & bolt, about M4 or M5, around 20-25mm long for the splitter or as short as you can find for the P clip. For everything else the original bolts/brackets etc. can be reused to secure the lines
      The Goodridge kit contains all the fittings for the brake lines themselves, incl. banjo bolts, replacements for the connectors at the master cylinder, and copper sealing washers.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    EVEN MORE OF A REASON!?
    I had this offer through from Busters advertising Goodridge Stainless hoses at £9.99 per line.
    Here's the link just in case it is a real bargain and anyone is considering it.
    http://www.busters-accessories.co.uk...prod=A%2DGDCAD
    Regards
    icenian's Avatar
    Jul 2004
    Votadinia
    Quote Originally Posted by BobA
    It sounds great, but you have to pay for all the extra bits too:
    3 lines: 29.97
    clear wrap for 3 lines: 4.50
    3 banjo bolts: 3.60
    delivery: 4.50
    total: 42.57
    Wez (wez@wezmoto.com) will do you a 3 line (front) kit for 39.95, incl. postage if you buy direct from him (rather than ebay). You also get the proper hose connector type fittings for the master cylinder, and it's not clear if Busters do that, or if it would cost more than a banjo bolt (priced above).
    I suppose you could do without the shrink wrap and then Busters would be 2 quid cheaper. Don't know if Wez does lines without shrink wrap.
  1. fitting Goodridge brake lines
    Last Post: 25-04-09, 03:11 PM
  2. Goodridge brake lines
    By icenian in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 15-03-07, 09:55 AM
  3. Stainless brake lines....
    By ger in forum Transalp
    Last Post: 14-09-06, 06:52 PM
  4. HEL brake lines
    Last Post: 15-04-05, 12:15 PM
  5. Stainless Brake Lines
    By mal in forum Africa Twin
    Last Post: 21-02-05, 11:27 AM
