Results 1 to 6 of 6
Thread: Blown Engine
    jahat_13 is offline Junior Member
    Blown Engine
    had a blown engine recently due to insufficient amt of engine oil,resulting in crack engine casing...so far..welded the casing..was wondering if any1 can find me a camshaft..pls advice...
    lootch67's Avatar
    South Ockendon, Essex
    Glad to hear I'm not the only one to whom this has recently happened. I managed to destoy my TDM's engine about a month ago. Decided to sell it to the breakers for about 25% of what it was worth before the egine went. Still, it gave me the ideal excuse to buy the AT so it wasn't all bad.
    And no, I have no idea where you can get a camshaft. Good luck!
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Re: Blown Engine
    Quote Originally Posted by jahat_13
    Mate it might be worthwhile giving us the details i.e.
    Is it a RD04 RD07, year etc etc.
    Where abouts are you based?
    my model is RD07,2001,black n gold ,base in singapore btw had the block welded but still hving probs with the crankshaft instead of the cam shaft that i mention earlier...found a used engine block y'day frm a shop at my place,the problem is the mechanic already used the crankshaft...wat im lackin now is the crankshaft...was wonderin if i had it repaired would it be as gd as b4,wld i still be able to go on long trips...im unwilling to sell my @,its the best bike i've riden.
    banger is offline Senior Member
    Aug 2004
    ireland
    had a blown engine recently due to insufficient amount of engine oil,
    How come your engine oil level went so low ? was it neglect or somthing ele..... just curious
    Banger
    Frankly speaking....neglect!!!!!!!didn chck the oil level...was for a long trip...listentening to Ipod(Metallica was on..wat do u expect,was singing along)didn pay attention to the red lite on the cockpit.so basicly my fault.
  1. What engine oil do you use?
    By Drawmer in forum Africa Twin
    Last Post: 28-05-11, 08:02 AM
  2. I need a new engine
    By sam h in forum Africa Twin
    Last Post: 26-01-07, 04:01 PM
  3. Which engine oil?
    By Cie in forum Chatter
    Last Post: 15-07-06, 05:30 PM
  4. new Engine Help!!
    By chalkzter in forum Africa Twin
    Last Post: 26-05-06, 12:02 PM
  5. Engine oil
    By Neil G in forum Transalp
    Last Post: 10-01-06, 05:59 PM
