I don't mind the fan coming on, off roading in England but I'm going to Morocco for a month on it, and hopefully staying of the tarmac as much as possible, thats why it would be nice to run it a bit cooler.
Surely, if the fan is coming on there is no problem....
I doubt the big H would have the stat and fan switch, set so high as to damage the motor. Look at it this way, in the Uk a bike fan rarely cuts in, so seems almost alarming when it does, I'm sure city travellers in much hotter countrys don't batter an eyelid when the fan's on nearly all the time! Also I doubt a different stat would make a difference as it'll be wide open at say 90*, fan might not cutin till over 100* so stat is wideopen anyway. If it bugs you fit a manual switch as mentioned. Phil
__________________
Safe House You can't take the Yorkshire out of a Yorkshire man |
My XRV650 trips the fan a lot. Temps here in WA state USA during the summer can reach 90 degrees (F). That makes the fan trip on whenever I'm at a stop for just a couple minutes. Both the TAs I've owned have been the same way. I wouldn't worry about it. Just be sure the coolant is fresh and at the correct level... and have a good trip.
| Bookmarks |
| Tags |
| hot, running |
| Thread Tools | |
| Display Modes | |
| Rich Running | nellychat | Africa Twin | 6 | 10-01-07 10:34 PM |
| Another AT running badly . . . | John | Africa Twin | 18 | 18-09-06 12:18 PM |
| running to rich | c stillythemanwivno | Africa Twin | 8 | 27-04-06 08:43 PM |
| Chain running in | africatijn | Africa Twin | 10 | 10-01-06 11:47 AM |
| running in | kev | Transalp | 4 | 20-11-05 04:13 PM |
