Results 1 to 7 of 7
Thread: What pipe goes here ? Air box Query ?
    tedmagnum's Avatar
    Jul 2005
    liverpool
    Hi, I posted an earlier thread asking what goes on this pipe. I still havnt worked it out so here a pictures to make things clearer..
    The bike is an RD07, year 2000
    Hope someone can help
    Chad's Avatar
    wickford,essex
    hi ted accroding to the manual one go's to the crank case breather
    and the other is a drain hose.
    let me know if you want a copy of the manual i have it on disk and will burn you a copy
    tedmagnum's Avatar
    Jul 2005
    liverpool
    Yer, i knew one was a crankcase breather. Im not sure which pipe goes where though.
    If you could email me a copy of the page you have it would be super useful mate..
    eddie@titaninet.co.uk
    Caveman's Avatar
    Caveman is offline Member
    Apr 2005
    Monk Sherborne, between Basingstoke and Newbury
    Airbox
    If I remember the rebuild of my bike, that looks like the Drain tube, some people have a tube attached to it, that goes down along with other drain tubes, some I know have left it free.
    Personally I would havea drain tube attached
    tedmagnum's Avatar
    Jul 2005
    liverpool
    The pipe on the picture on the right is a draintube. What goes on the left ???
    Is the pipe meant to go on the left or the right.
    ta
    Caveman's Avatar
    Apr 2005
    Airbox
    I don't know whether yours or mine is connected the wrong way round then.
    The one on the right on mine, is the crankcase breather tube and the one one the left is the drain tube.
    I'd check to see if you have a tube that has a Y peice in it. That tube has one leg that goes to the airbox, the other to the crankcase. It may be easier to trace from the bottom, as this part is the one that has the screw cap on the end, which when you take the end of, usually has some sludgy oil in mixed with water. (Don't worry about the water, it's just condensation.)
    Best of luck
    tedmagnum's Avatar
    Jul 2005
    liverpool
    The problem i have is that the bike was completly stripped no have nothing to trace from.
    Ill put the drain tube on the left, but i dont have any spare pipes which would fit on the other hole. Where abouts does the tube route too for the crankcase breather ? this pipe may have already been missing when i bought it
  1. RD3/RD4 Query
    By jay in forum Africa Twin
    Last Post: 20-11-06, 07:30 PM
  2. Dealer query
    By Taz in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 18-06-06, 09:24 PM
  3. Airbox pipe fitting query
    Last Post: 26-09-05, 02:40 PM
  4. Speedo Cable Query
    By miggy in forum Africa Twin
    Last Post: 04-03-05, 11:47 AM
