Results 1 to 9 of 9
Thread: would one missing headlamp make battery go flat
    c stillythemanwivno Guest
    just a quick question..........................
    Caveman's Avatar
    Caveman is offline Member
    Apr 2005
    Monk Sherborne, between Basingstoke and Newbury
    Flat Battery?
    Shouldn't, but depends on how you carried out the mod and terminated the other feed, the relay is designed to be loaded by two bulbs.
    If you have a flat battery, it could be the other feed is shorting out, which would cause a problem
    Cotswolds, UK
    No. I actually disconnected one headlight so save power when my rectifier was on its way out: It just made the difference between having a bit of juice left to charge instead of flattening the battery.
    However, if your failing headlight is a result of some short-cut / bad earth it could have the opposite effect. I would either fix it or remove the connector completely from the failing bulb and cover it in tape.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Unless you have a wiring fault, I don't think so.
    If one headlamp is working correctly, they both work in parallel, so chances are the + feed and relays are OK. Also, the headlamps are on an ignition controlled circuit, so the ignition would have to be on, as well as the headlamp switch to make the lighting circuit work.
    I think I've got that right
    o shame me bike is going to get electrics seen to on saturday they should sort it battery keep going flat 3rd time now ? i brought new batt propper honda one still no joy ive used the chart someone posted on charging systems i have no choice its going in ...............
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Have you got a alarm system of some sort fitted? They sometimes do drain the battery when things go wrong
    Cotswolds, UK
    Does is it go flat while riding it, or even when it is just parked up in the garage? If it happens during use, I am afraid it is just another one of Honda's infamous rectifier/regulator gone to the dogs. Otherwise, there must be a short somewhere. Use a multimeter to analyse, you can find some test scenarios in good ol' Haynes. Good luck!
    i am not going to think about it any more ive tried my best to sort it yes could be the alarm it could or maybe shorting out ????? well im shure me man will find it he is good with the honda ...... and only 13 pounds an hour ............
    oh yes thanks for all the suggestions .............. ill pass on this one
  1. Fitting headlamp bulb on xl650v- Help!
    By stumpylegs in forum Transalp
    Last Post: 31-12-06, 03:50 PM
  2. Got a flat and need a tube
    Last Post: 27-12-06, 06:24 PM
  3. FLAT TYRES
    By caRnaf in forum Chatter
    Last Post: 15-12-05, 10:26 PM
  4. WANTED RICKI CROSS HEADLAMP PROTECTOR
    By mikeW in forum Africa Twin
    Last Post: 01-01-70, 05:46 PM
