Specifications
Hi all
Can any of you tell me the Model Changes for the @.
I am interested in the Rear Sub frame ,
And the Exhaust .
Other than that the @ has pretty much stayed the Same ?
Pray tell
rear subframe .... im a bit of an expert here ... lol...
RD03 bolt on I believe... RD04 - Dunno .. RD07 / RD07A Rear subframe welded to main chassis (if its bent, I know a company that can fix them !)
exhaust seems to hang off a bracket from the rear subframe. again, RD03/04 different to RD07/07A
No exactly
What i need to know is what Rear Subframe for what year.There was only one frame up date on an AT but what year
There was also an exhaust update , again what year.
The last major update was to the P model (RD07) in 1993. I think the rear subframe was changed then as the seat height changed from 880 to 860. The very last update was made in 1996 to the T model (RD07A). The only changes from then on were to paint schemes. So if your intending to make frames for the RD07 then you'd be be safe with any bike manufactured from 96 onward. LB.
Try trawling through the microfiche and parts lists in the Tech Data section at the top of this page.
- You may not post replies
- You may not edit your posts
Forum Rules
