Results 1 to 7 of 7
Thread: Chain Slider
    Slimie is offline Huh?
    Devon, proper job!!
    Chain Slider
    I drove about 450 miles in the pouring rain the other day and when I parked up and looked around the bike I noticed that the chain had been polished to quite a good shine on the inner sideplates.
    I've finally managed to have a good look and it looks as though the lower chain slider has two slots deep enough cause this polishing.
    So, I'm assuming that this is a sacrificial part (the slider), and wonder how easy is it to replace - is this a normal service part?
    Secondly , after taking the bashplate off I discovered that the tabs that should be holding it to the front of the frame aren't. They've broken off and now only the crashbars are holding the front edge in palce. My thinking is that it's probably OK like this, but I'd welcome any opinions!
    Thanks in advance
    -Simon
    Devon, proper job!!
    Forgot to mention that I'm assuming that the rain washed off most of the Scottoilers oil - I forgot to increase the drippage, D'oh!
    -Simon
    Re: Chain Slider
    Quote Originally Posted by Slimie
    Thanks in advance
    -Simon
    Two grooves is normal, it is sacrificial. The time to change it is when the grooves are nearly as deep as the outside depth otherwise the chain will eat your swingarm. To change it should really require the removal of the swing arm, but on my old DR350 I just cut through the part that goes around the swing arm pivot, pushed it on and bolted it to the swingarm as normal and it was fine for years after.
    Devon, proper job!!
    Cheers Yen, thanks for the advice
    Chad's Avatar
    wickford,essex
    slimie . it might be ad visable to get your bash plate mount fixed . ive got the same problem on mine but only on one side . i will be rewelding mine some time after the 13th sailsbury plain meet .if you fancy the ride out to mine i'll sort them for you , you bring the biscuits i'll supply the welding and coffee
    Devon, proper job!!
    That sounds like a plan to me, I'll have a chat with you on Sunday!
    -Simon
    Chad's Avatar
    wickford,essex
    no problem mate
  1. Swinging arm Chain Slider
    Last Post: 11-10-10, 01:58 AM
  2. New chain etc
    Last Post: 23-06-10, 05:41 PM
  3. New Chain
    By zorza in forum Africa Twin
    Last Post: 04-07-06, 01:20 PM
  4. CHAIN FOR AT.
    By ruterovenezuela in forum Africa Twin
    Last Post: 06-04-06, 07:26 PM
  5. Chain(again)
    By mal in forum Africa Twin
    Last Post: 17-03-05, 09:51 AM
