Results 1 to 2 of 2
Thread: ass on fire
    saintvice is offline Junior Member
    Accra Ghana WestAfrica
    ass on fire
    well today was not a good day..
    i sent the bike in yesterday to fix the tacho meter<sp> they fixed it.. said it was a wiring fault.. so that was sorted.. today on my way to work smoke started coming out from under my seat... i paniced.. before i could switch off the ignition the bike went off.. so i turned the key off and pushed the bike aside... was scared ****less cos i had forgotten my tools. so i asked around and got some removed the sides and the seat.. looked around and didnt see anything... got the mech to check it out.. he said my rectifier was blown... now is that possible? what can cause the rectifier to blow?
    zorba is offline Mr
    Jan 2004
    Greece
    The rectifier is a common problem with africas. I had mine blown last year and I have a 93 model.
    Remove the left side cover and you will probably be able to find it.
    It is the black box with cooler fins.
    Follow the cables and you will probably find them to be corroded or melted.
  1. back fire
    By tumper in forum Dominator / FMX
    Last Post: 18-10-06, 12:42 PM
  2. Fire in the hole!
    By gibbo in forum Africa Twin
    Last Post: 18-12-04, 05:18 PM
