I noticed (amongst another series of brake-related mysteries) one of the front caliper has difficulty sliding over the caliper-bracket's slider pins. One brake pad (the one near the pistons) is a lot more worn than the opposite one so I suspect these two events are related. Also, the other caliper still slides happily and the pads are virtually the same thickness, looks like another proof. Unless anyone here thinks differently?
Well then.
I want to split the caliper from the bracket to clean and grease it all up.
Haynes says (chapter 7, paragraph 4.5): "Separate the caliper from the bracket by sliding them apart (see illustration)"
The lovely illustration shows something that is quite dissimilar from what I see in my humbe garage: The caliper hardly slides over the pins, let alone is anywhere near coming apart![]()
Any golden tips from the experts here? Apply brute force? Buy a new caliper? Or a new bike? :P )
Thanks in advance!
