Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Africa Twin
Reply
  #1 (permalink)
Old 10-12-05, 08:23 PM
DaveS's Avatar
XRV Site Owner
Sw Motech Panniers Rails & Honda Top Box
I've been fitting my SW Motech Pannier rails and the panniers.
I've run in to a problem with my Honda Topbox. I have the big jobbie, 55 litres I think.
It basically won't quite fit with my panniers on.
Some pics to illustrate are at the bottom.
I need to move my topbox up and backwards a bit.
I'd wanted to move my topbox backwards anyway as I could then fit a full size pillion on without squashing my nuts against the tank.
To do this I think I need something underneath the plate that the topbox fixes to. Although it needs to be reasonably substantial.
So I'm looking for a piece of aluminium tubing that's about 1.5 inches square and a foot long.
Anyone any ideas where I might get that from, and am I going the right way about this?
__________________
Forum help and advice needed?
2003 BMW R1150GS ABS EVO
2002 Honda XR400R
Camping related questions and advice? Come and join in the discussions at Camping Forums UK.
Follow xrv.org.uk on Twitter.
  #2 (permalink)
Old 10-12-05, 08:47 PM
Senior Member
How about some tubular spacers?
You can get some metal tube preferably aluminium from B&Q or any local metal merchant as large a diameter as possible for the best support with suitable washers to use as bearers and simply cut them to the size needed with longer bolts.
Give us some pics of the crash bars. I've just got some myself but haven't fitted them yet
  #3 (permalink)
Old 11-12-05, 12:49 AM
Chad's Avatar
dave i have some 25mm box section in steel if you want it let me know if thats any good and how much you need and i'll send it through to you mate
__________________
Why is the rum always gone
GS1150ADV
FAST BLACK AND better specced than a Maybach
I'm fortunate to have a chemical engineering background, and one of the things I enjoy most is turning beer, wine,vodka,Scotch, and margaritas into urine.
TOXIC'S RUNNING OUT OF PATIENCE
dont hide behind your computer get your ass out there and meet your fellow members
  #4 (permalink)
Old 11-12-05, 09:48 AM
DaveS's Avatar
XRV Site Owner
Thanks mate.
I didn't want steel due to the weight and finish. I'll see what I can find in alu first, but thanks.
__________________
2002 Honda XR400R
  #5 (permalink)
Old 11-12-05, 09:57 AM
Cie's Avatar
Cie Cie is offline
Advanced riding bore
Send a message via ICQ to Cie Send a message via MSN to Cie Send a message via Skype™ to Cie
Does it have to be square?
Aluminium scacffold poles are thick wall aluminium, and 2" diameter, which I have here
  #6 (permalink)
Old 11-12-05, 10:05 AM
DaveS's Avatar
XRV Site Owner
I think so for the strength. Its going to have a top box rack and top box sitting on it so it needs to be strong.
For instance I didn't think I made myself clear, but in the photo's I've already moved the top box plate backwards on the rack.
It only fixes by 4 of the holes now not 6 and it flexes too much. I also want to raise it a bit hence I need to build something solid that fits between the rack and the top box plate.
I think this is exactly what I want to do. I'm going to have a look round B&Q today to see what I can find.
__________________
2002 Honda XR400R
  #7 (permalink)
Old 11-12-05, 10:12 AM
Cie's Avatar
Cie Cie is offline
In reply to that then.. if you have no luck at B&Q, the 2 inch scaffold pole can be cut to the vertical length you require, effectively giving you 2 inch diameter, thick wall aluminium spacers that you can cut to any lenghth you choose, be that 5mm or 5 inches.
Anyway, the offer stands
  #8 (permalink)
Old 11-12-05, 10:23 AM
Chad's Avatar
as you go give us some pics so we can see how it comes out dave
__________________
GS1150ADV
  #9 (permalink)
Old 11-12-05, 04:30 PM
xrv_jim's Avatar
Cracking cheese Gromit!
Re: Sw Motech Panniers Rails & Honda Top Box
Don't know what the Motech fittings are like but can't the panniers be mounted a bit further down and wouldn't that provide clearance for the top box? I can't see clearly from your pics, but it does look like there's a bit of room to play with and I do remember seeing another post showing the Alphos boxes on the Motech rack and thinking they looked a little high.
__________________
'94 XRV750R
'91 FJ1200
'81 XT250
If it ain't broke, fix it 'til it is.
  #10 (permalink)
Old 11-12-05, 08:00 PM
DaveS's Avatar
XRV Site Owner
Quote:
Unfortunately not. I can't see anyway they can drop down. The panniers sit on a frame that is itself bolted to the pannier rails. To get anything to drop lower would require that holes be redrilled and that wouldn't be easy.
I've had a dig around B&Q, et al, today and come up with nothing.
Don't want to use spacers between the top box plate and the rack as it overhangs at the back, and I need it fixed solidly to both.
So my ideal is a solid lump of alu that bolts between the plate and the rack. One of my major requirements is that it must look good though!
Anyway I'l keep playing and see what I can come up with.
__________________
2002 Honda XR400R
Reply
Tags
box, honda, motech, panniers, rails, sw
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda/Hepco & Becker Panniers. Help Kerbs Africa Twin 14 29-06-06 01:30 AM
Honda OE panniers Man up North Africa Twin 3 23-02-06 12:56 PM
Honda Panniers on Africa Twin Drawmer Africa Twin 1 22-10-05 06:05 PM
SW-Motech Quick Lock Frames and Panniers Gregger Africa Twin 7 25-08-05 11:26 AM
