Results 1 to 10 of 12
Thread: speedo cable
    jabba's Avatar
    speedo cable
    Its finally gone at 25500 miles waiting for a replacement from hi level.
    Problem is no speedo loads of speed cameras in wales needless to say much going slow just incase
    rossco is offline Member
    Oct 2004
    Cardiff
    12 inch
    been having fun with that as well
    30mph 2nd Gear 4k rpm 3rd Gear 3k rpm
    40mph 3rd Gear 4k rpm
    50mph 3rd Gear 5k rpm 4th gear 4-4.5k rpm 5th gear 3.5k rpm
    70mph 5th Gear 5k rpm.
    Well thats what I am sticking too waiting for the nylon gear thingy to turn up. Dont think it will wash the the old bill if I get busted but I am trying, the problem is I havent worked out what 80mph is, I think its around 6k rpm in 5th but could be well off.
    Cotswolds, UK
    In my experience it is the best to choose an OE cable as replacement. I have had two aftermarket ones from different sources. They were supposed to be "specially made for the AT", but none of them had the same length as the OE cable (one was a bit shorter, the other one a lot longer ) and (therefore?) did not last very long. Also make sure the cable is correctly "routed".
    PS riding without speedo: As soon as the bike starts to loose its tendency to stay upright, it is probably safe to open the throttle a little bit more without immediate risk of breaking the law
    If you have trouble getting a cable soon enough, why not spend a few quid on a electronic "push-bike" speedo from Cat-Eye for example? On eBay you can get a simple one for almost next-to-nothing, just make sure they are up to high-enough speeds. They are not very useful in the dark though unless you have cat-eyes yourself.
    Re: 12 inch
    Quote Originally Posted by rossco
    80 mph is just a tadge (a metric tadge) over 6,000 rpm with half worn tyres.
    wheeliebin's Avatar
    N/A
    Can anyone give me a measurement for the AT speedo cable (length).
    Need a longer one for my TA.
    fw600vj is offline Senior Member
    Jul 2004
    belfast
    Hi Wheeliebin the lenth of the @ speedo cable is 36 and a half inches or 93 centimetres .The Honda part number is 44830-may-620 . When i bought it from a Honda Dealer it cost me £15.50.Hope this helps fw600vj
    wheeliebin's Avatar
    N/A
    Many thanks
    Oct 2004
    Cardiff
    Many thanks Yen,
    I might just not bother fixing the speedo, dont know if you need a working speedo to pass the MOT I suspect not as they dont seem to ride the bike off anywhere.
    Makes the bikes mileage a little off though
    Many thanks Yen,
    Speedo is not part of the MOT. However if the tester carries out a test ride, as he has a right to do if he wants to check something on road, he may well decide it's unsafe if the speedo doesn't let him know how fast he's going. However, I've only once seen a tester do a test ride, that was on my mates Transalp to confirm slightly warped front dic.
    jabba's Avatar
    ok got one and my god its a whoppa supplied by hi level which you can obtain through any bike shop.
    And when I mean long it must be 6 inches longer than the honda one still its working and for 8 quid(friend who owns a shop) I aint complaining.
    If it bugs me though genuine honda methinks
  1. Speedo- It's not the cable!
    By louis_holtz in forum Africa Twin
    Last Post: 12-06-07, 09:27 PM
  2. GPS power cable
    By mladen in forum Africa Twin
    Last Post: 12-01-07, 08:47 PM
  3. changing a speedo cable, how?
    By Dickster in forum Transalp
    Last Post: 31-01-06, 09:34 AM
  4. Speedo Cable Query
    By miggy in forum Africa Twin
    Last Post: 04-03-05, 11:47 AM
