I have an annoying problem with my Autocom.
It is the Active Rider 200 kit.
Basically I think I have a loose connection or poor connection somewhere in the system.
It is hard wired to the bike, fitted under the seat with my cable running up between the seat and tank and pillion running under the seat and out by the exhaust but not close enough to get hot.
We have the straight headset extension leads then connected to the helmets.
All has worked fine for 10 months but the last few times the sound comes and goes.
Say the music is on all is well then I hit a bump in the road and I loose the sound in one ear, I get horrible crackling noise and sometimes can loose it all together.
It is not the VOX for sure.
If I have the ignition on and then connect the pillion lead it nearly blows your head off with an electrical noise.
Yesterday I went to the local dealer and tried a different headset different leads and still the same.
It seems to point and the connections that are left exposed when they are not in use, the ones you plug the helmet leads into,
Is there any thing to clean these with ? I dont want to just spray WD40 on them if its not the right thing to do
Please help as its doing my head in LITERALLY
Cheers in advance![]()
