Sticky Throttle Grip?
For some reason my throttle grip no longer springs back as it should when you take your hand off it. The Grips don’t seem to be rubbing on anything but it still sticks. I have tried to spray it with WD40 but it seems to make little difference. Only positive thing is on start up at least I can set it at a few revs to get the engine warm while I unlock it.
Any ideas how to solve the problem?
__________________
1993 XL600V Transalp http://www.bikepics.com/members/grendel/93xl600v/ My TA 600 Page: http://www.facebook.com/group.php?gi...2079&ref=share Southampton Safe house |
Re: Sticky Throttle Grip?
Also remember that some cables with a nylon inner don;t like being oiled as the oil makes the nylon swell and jam
__________________
Super Ténéré Owners Forum...........Cable Forum UK Honda Trail Bikes Owners Forum...........Camping Forum UK |
It only started happening as the rethal grips started to dietarian. But can’t see anywhere it may be rubbing but will lube cable with silicon spray tomorrow and see if that solves it. Thanks folks
__________________
Good timing this, mine has been doing the same for a few days now, so will oil the cables as described, thanks guys n gals
__________________
XL650 '06 In Black Elizabeth Kubler-Ross: Quotes: Adventure It is only when we truly know and understand that we have a limited time on earth and that we have no way of knowing when our time is up that we will begin to live each day to the fullest, as if it were the only one we had. |
Took it apart last night and it looked dry and dirty gave it a liberal coating of WD40 since had run out of silicon spray then left to soak over night. Went for a test drive today and WOW what a difference smoother throttle response and acceleration all this time I thought the juddering throttle control way my bad riding
__________________
| Bookmarks |
| Tags |
| grip, sticky, throttle |
| Thread Tools | |
| Display Modes | |
| XR400 Throttle Grip/Tube | kiwijohn | XR | 1 | 15-05-09 02:16 PM |
| Easy assembly of Honda throttle twist grip | piguglyshandydrinker | Bodgers Corner | 1 | 16-03-09 11:43 PM |
| How much difference in grip? | Grendel | Transalp | 2 | 16-03-08 09:21 PM |
| How do you stick a heated grip to the throttle body? | Austin | Bike Tech | 16 | 12-11-07 01:56 PM |
| Grip Help | shack | Africa Twin | 13 | 28-06-07 08:31 AM |
