Re: Spark Plugs
The spark plug is like a mini arc welding rod.
As it arcs the surfaces of the plug vaporize, Add to that the fact that it is in a high pressure high heat environment. This has a detrimental effect on the plug over time.
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE |
Re: Spark Plugs
It's also not just that... the cores continually heat up and expand and then cool down and contract, eventually the cores either break and you get the cylinder hard to start when cold, or the insulator cracks and can drop sections into the piston... Also on resistor plugs the resistance can change altering the engine running
Always best to swap them out every couple of years even if you've not ran them for a lot of milage..
__________________
Super Ténéré Owners Forum...........Cable Forum UK Honda Trail Bikes Owners Forum...........Camping Forum UK |
Re: Spark Plugs
also if they are resistor plugs the resistors break down over time usually a short period if my experience is anything to go by, and occasionally iffy batches of plugs get into the market so if you replace a plug and it is worse it is possible the new one is the problem
__________________
Handle every stressful situation like a dog I you cannot eat it or hump it piss on it and walk away |
Re: Spark Plugs
Quote:
I tend to replace plugs, filter & oil every 6K. is that too quick for plugs?
__________________
'52 TA Honda top box, HID conversion, 47T rear sprocket, K&N air filter, Tourances rubber "Minds are like parachutes - they only function when open" |
Re: Spark Plugs
Depends who you ask, how often you use the bike, whether it used daily or just long trips... In hot/cold weather..
Short frequent trips in cold weather is worse for the thermal shock.. Personally I swap mine round every two years when the bike is active, but when I was a courier it was every 3 months (but I was doing 80K+ a year)
__________________
| Bookmarks |
| Tags |
| plugs, spark |
| Thread Tools | |
| Display Modes | |
| Spark plugs | paul_r | Africa Twin | 6 | 20-05-08 09:47 PM |
| Getting out the spark plugs ... | idefix | Transalp | 5 | 22-01-08 09:17 PM |
| spark plugs | captaincaveman | Africa Twin | 16 | 13-09-06 09:53 PM |
| spark plugs | P&J | Africa Twin | 5 | 10-07-06 09:35 AM |
| spark plugs | Les666 | Africa Twin | 11 | 25-05-05 05:46 AM |
