After a long time looking and thinking about having a go at makeing some panniers iv finnaly got round to it
As thay say when the boss is away the boys will play.
I got hold of some 3mm aluminium sheet and 3mm 2 1/2 cm x 2 1/2cm aluminium angle and sused out how to work the sheet metal cutter, so far so good,
Then started on the angle, now im no enginering god and it showed when i tryed to cut it to length and at a 45% angle but i got there in the end.
So far i have 2 box's held together with 4mm bolts.
Q, iv herd of people using steel rivets but wont they rust easy? and is there much in the strength?
I understand they could be stronger but if they do rust quite easy i might use alloy one's and get them spot welded on the inside just to strengthen them if thats doable.
I would just use the 4mm nut's but they look like they could catch on the in side even theo im going to line the inside with a canoe bag to help water proof and could hurt if i was to catch myself or someone.
So far its only taken me about 5hrs which i think is good for a first time experiment (i think thats what id call it)
Any advice would be much appretiated
