I have acquired some 30mm x 5mm steel flat bar and I am in the process of making a Jerry can bracket and mount for my Ural.
I won't be doing the welding, but I am prepping all the lengths of metal that I will then bend and twist to that , once welded, they will form my can holder.
I am measuring up the Jerry can and cutting the bar accordingly. I am giving myself a bit of extra for now, but once I start working the metal down to the exact lengths I want so that the jerry can is snug, do I need to allow any length variation for the welding so that the finished article is the size I am planning for?
In other words, if my Jerry Can is 37cm wide, do I need to allow any extra metal for the weld, or should I even take a bit off to account for the material the weld will lay down?
I don't want to slave as I have been today for it all to be a few mm too small for the can to fit!!!
